Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
Jammed lower rod adjuster... Floor shift.
« previous
next »
Print
Pages: [
1
Author
Topic: Jammed lower rod adjuster... Floor shift. (Read 737 times)
LEMOOREACE
Jr. Member
I was a llama, but I have since evolved.
on:
October 18, 2012 - 09:23:01 AM »
Anybody have a good idea how to un-jam the sliding adjusting block on the lower rod automatic (console) linkage. Mine won't slide up and down the rod after pulling loose the locking bolt. Mine is stuck good! The "adjustable swivel"...
Last Edit: October 18, 2012 - 09:26:00 AM by LEMOOREACE
Logged
burdar
Sr. Resident
Re: Jammed lower rod adjuster... Floor shift.
Reply #1 on:
October 18, 2012 - 09:29:59 AM »
Remove the cotter pins from the trans shift arm and from the pivot that comes down through the floor. You'll be able to remove that entire ajustment arm from the car. Then it's just a matter of soaking the connection with some penitrating oil.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #2 on:
October 18, 2012 - 09:32:14 AM »
I would heat it with a propane torch & use penetrant , apparently a mix of acetone & Auto trans fluid will work better than any penetrating oil
Logged
LEMOOREACE
Jr. Member
Reply #3 on:
October 18, 2012 - 09:41:26 AM »
Thanks for the advice. I did have it out of the car, but I didn't want to brutilize it anymore with a hammer and damage it... Amazing the grip this thing has on the rod because it won't budge...
Logged
blknout
Jr. Member
Reply #4 on:
October 18, 2012 - 07:24:22 PM »
if you cant get it free. I got them too if you need it
Logged
1973 dodge challenger 440 4 speed 391 posi
2001 dodge ram 1500 4x4 offroad sport
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
