Author Topic: Broken sway bar bracket  (Read 783 times)
Offline 72cuda
  • mmmmm, boiling gas
« on: February 26, 2005 - 04:52:23 PM »
While working on the front end today, I noticed that the sway bar mounting bracket on the drivers side LCA is broken.
A chunk is missing from the front of the hole.
Has anyone repaired/replaced this bracket? I'd hate to replace the whole arm just because of this.
Thanks.
72 Cuda 383 4-spd
Drive it like you paid for it
Re: Broken sway bar bracket
« Reply #1 on: February 27, 2005 - 11:01:42 AM »
I guess it depends on your fabrication skills , it would not be hard to weld in a re-inforcement plate to repair the bracket or weld a new bracket on
Offline 72cuda
« Reply #2 on: February 27, 2005 - 04:17:56 PM »
It loolks like you can just grind the top off and weld on a D-washer.
72 Cuda 383 4-spd
