Author Topic: a833 pops out of 3rd gear  (Read 7314 times)
Re: a833 pops out of 3rd gear
« Reply #15 on: November 12, 2012 - 08:18:31 AM »
Glad you got it solved , this is exactly how I have learned to fix virtually anything , just cannot trust anyone else to do things right
« Reply #16 on: November 12, 2012 - 08:18:54 AM »
Good to hear you got it sorted out. To bad about "Harry's"  :pullinghair:
Offline 1970 440 RT's
  • 1970 RT
« Reply #17 on: November 12, 2012 - 07:01:24 PM »
Thanks CP and Brad!
Leaned alot so far from you two about what I do and do not want to do to the car!
In another update, I put the Lunati 60303 cam in, in place of the mp509.   Definitely idles much better and don't have to start it 3 times and run it up when it is cold anymore!
But, it seems just a tad weaker at the high end now, and I was wondering if I should step up to the 60304?  ...or is the 60304 too sloppy down low like the 509?
I also have Edlebrock heads and TTI 1 7/8" Headers sitting on the floor waiting patiently for install...
Currently it has HP Ex. manifolds and 915 heads w/3" tti.  Should I step up to the bigger cam, or just put the heads and headers on first?
Thanks!
'70 Challenger R/T 440 4 spd Dana EF8
« Reply #18 on: November 12, 2012 - 11:12:16 PM »
you would still have less duration with the 60304 from the .509
 If you do the head swap & would love to see you run the engine tuned on a  dyno before the eddy heads & after if you do the swap , , I gained 3 hp over poredt 452 heads & your 915s are better heads than the 452s  !
 I would do the headers first , swap the cam & then think about swapping the heads at all !!
Offline HP_Cuda
  • Mopar or No Car!
A833
« Reply #19 on: November 17, 2012 - 01:07:59 PM »
Glad to hear it worked out for you.
Word to the wise, if you are looking for transmission work make sure you find someone who knows A833's.
I got one of the top notch guys on the west coast and it's a work of art! Wouldn't hesitate one second to take it to him again.
Bryan
