Author Topic: Mopar Performance P3690731  (Read 2344 times)
Offline tvacuda340
  • F1A procharger 422 small block
« on: October 21, 2012 - 06:45:19 AM »
hi there
are any running a blue Mopar Performance Voltage Regulators ( Voltage is held at a costant 13.5 volts ] on the street ?
i have a littel problem at idle  700 rpm when running with  2 fan+fuel pumps + headslights   volt can drob to 11 volt  ...at higher rpm  1200 no problems show   14 volt
Offline Katfish
  • 70 Challenger
Re: Mopar Performance P3690731
« Reply #1 on: October 21, 2012 - 08:04:43 AM »
Have you considered putting in relays and running the extras directly from the battery?
« Reply #2 on: October 21, 2012 - 09:23:07 AM »
A different reg will not help , at idle your alt is simply not making enough power for all the accessories , using a modern alt may help such as a Denso unit .
Offline tvacuda340
« Reply #3 on: October 21, 2012 - 09:31:48 AM »
already doing that !
Offline tvacuda340
« Reply #4 on: October 21, 2012 - 09:33:31 AM »
any proposals that will fit  small block ?
« Reply #5 on: October 21, 2012 - 11:47:49 AM »
I believe both Mancini & 440 Source have conversion kits with brackets
Offline tvacuda340
« Reply #6 on: October 21, 2012 - 02:46:00 PM »
thanks  and grettings from denmark  we need a danish flag to
« Reply #7 on: October 21, 2012 - 09:09:12 PM »
We have at least 2 members from Denmark I believe now  :2thumbs:
