Author Topic: 1970 gran coupe trim,carb,bracket  (Read 781 times)
Offline tailfins
« on: October 21, 2012 - 04:24:49 PM »
need the 2 trim pcs on tops of doors and the 'bbomerang'shaped piece on drivers rear panel around tailite
also need correct 4bbl carb+distr for 383 4spd engine,non-smog
right front bumper brkt
lower front windshield stainless+clips
radio spkr+grille
thanks
Offline rave_12000
Re: 1970 gran coupe trim,carb,bracket
« Reply #1 on: October 22, 2012 - 10:05:35 AM »
i have front stainless and speaker grille in black.
mike 816-799-8844
Offline Jamiez
  • Retro
« Reply #2 on: October 22, 2012 - 12:14:21 PM »
Apparently in 1970 it depends on some more options:
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Board=QuestionAnswer&Number=7265518&Searchpage=1&Main=7265518&Words=+patbee383&topic=&Search=true
So I guess it depends if you had N96, since you said Non-Smog (i.e. no N95)
Offline A93
« Reply #3 on: October 28, 2012 - 10:34:08 PM »
radio spkr+grille
thanks
I have several of the Holley 383+4 four speed carbs. Are you needing a certain date? What is the SPD of your car? I may also have the distributor. Send me a message  and we can go from there.
