Author Topic: Moser Dana 60. Adding a pinion snubber. What size bolts will I need?  (Read 840 times)
Offline willhaven
I dug through the "snubber" threads and found mostly threads about clearance, but nothing about what actual bolt size is required to bolt on the snubber.
Anyone know offhand?
I'm getting the Strange stock type snubber replacement, if that helps. It didn't look like it actually came with the bolts either.
The car is so low it's banged the bottom of the tunnel a few times now. I've seen indentations from the driveshaft joint as well.  :sly:
Re: Moser Dana 60. Adding a pinion snubber. What size bolts will I need?
« Reply #1 on: October 22, 2012 - 09:21:55 PM »
5/16 or 3/8 coarse thread about 1" long
Offline willhaven
« Reply #2 on: October 22, 2012 - 09:50:55 PM »
That should steer me in the right direction. Cheers!
