I'm pretty sure I'm going with the Atomic. I like that the installation looks a little cleaner than the other systems and the Atomic throttle body will look better with the type of air cleaner I use.
Joe,
After I worked on an '81 Chrysler Imperial with the fuel injection electronics all mounted inside the air cleaner and seeing all of the potting material all oozed out because of heat, I would stay away from anything that mounts it's electronics on top of the engine. The Atomic and the BossEFI systems are 2 that mount their complete efi computer inside the throttle bodies.
I've dealt with electronics for years and know that the cooler you keep the components and solder connections, the longer they will last.
I can't imagine how hot the top of my 440 gets with the hood closed, when shutting it off after a long summer drive with the AC on.
My EFI ECUs ride inside the cabin with me. The FAST system also comes with a lifetime warranty. I'm not sure if anyone else does that. It's your money so get what you want.
