Author Topic: Converting the fuel tank to EFI?  (Read 22882 times)
Offline cudagirl4406pk
    • Garageartmusclecars
Re: Converting the fuel tank to EFI?
« Reply #45 on: December 29, 2013 - 10:25:38 AM »
Here is tank under my cuda
Offline roadrunninMark
« Reply #46 on: December 29, 2013 - 06:31:58 PM »
Michele,
How many gallons does that hold compared to the stock tank?  What did you do about a fuel gauge and can you use the stock gauge?
« Reply #47 on: January 02, 2014 - 12:32:38 PM »
Tank hold 18 gallons and yes you can use the stock guage they put the sending unit in the tank to match the 73ohms you have ii have a autometer custom setup so it works better then stock.Contact jeff at hotrodcitygarage.com  tell him michele with the orange cuda sent you.
michele
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #48 on: February 04, 2014 - 07:53:35 AM »
You will have to modify the shock tower support for the fuel lines to clear other than that its a bolt in tank
« Reply #49 on: February 04, 2014 - 08:24:31 AM »
John, maybe weld some tubing in the frame rail were you drilled the holes for the fuel lines? Stronger, easier on the fuel lines? :dunno:
I'm coming down to your neck of the woods in March. Maybe we can get together and drool over your car? :wave:
« Reply #50 on: February 05, 2014 - 07:26:55 AM »
Cool !!!!
