Author Topic: Yearone 17inch Rallye  (Read 57885 times)
Offline mildphil
  • Jack of all trades
Re: Yearone 17inch Rallye
« Reply #105 on: February 26, 2013 - 07:05:19 PM »
any clearance issues with these? do you need to do any changes or can you put these on and go?
Nothing last forever, so be thankful for what you have while you still have it. :)
Offline 72bluNblu
« Reply #106 on: February 26, 2013 - 08:41:40 PM »
The 17x8's should bolt right on and go, shouldn't have any clearance issues front or rear. The 17x9's will be tight depending on your tire choice with stock components, front and rear. I run 17x9's with 275/40/17's all the way around, but I had a mild rub on my right front fender until I re-adjusted the alignment (more negative camber). I have a B body rear with 1" relocated springs, so I'm way clear in the back. On a stock car it would be tight, probably come down to body tolerances front and rear with the 17x9's and something as wide as a 275.
Offline 7212Mopar
« Reply #107 on: April 18, 2013 - 03:57:09 PM »
Just noticed that Yearone now has the Rallye wheels in staggered configuration in a front and back package, 17x8 front and 17x9 back. This will save a few bucks compare to buying different sizes separately. Thinking to place my order next month. I have the stock 14" Magnum on the car now.
1973 Challenger Rallye, AT with 1971 340
2012 Challenger SRT8 392 YJ,  6 spd
Offline shoooter
« Reply #108 on: May 22, 2013 - 02:17:21 AM »
cant wait to see a set on a 71 cuda :droolingbounce:
Offline challenger_affair
« Reply #109 on: December 14, 2013 - 03:55:22 AM »
I'm going to need some new tires and since I currently have original 14" rallye's I'm seriously considering this alternative...  Since most of the discussion here is from the beginning of the year, can anyone share further experiences with these wheels in the intervening months?  Backspacing, tire combos, fittment issues??
 :popcorn:
1970 Challenger 383 RT Auto Plum Crazy
Offline hemiken
« Reply #110 on: December 14, 2013 - 05:26:41 AM »
Have any other guys bought these wheels and fitted them, would love to see some more if possible please guys :wave:
Offline drewcrane
« Reply #111 on: December 14, 2013 - 08:24:59 AM »
I was so close to buying them but I just cant make the change,I love cool custom wheels but until I see them in person I just cant bite the bullet
 :useless:
someone else have em yet?
« Reply #112 on: December 14, 2013 - 08:48:33 AM »
 :useless:
found  http://www.dodgecharger.com/forum/index.php?PHPSESSID=bkafv11iaoiblfp7obu5rp1c47&topic=97177.msg1142169#msg1142169
http://www.drivinithome.com/yearone-mopar-rallye-wheels/
« Reply #113 on: December 14, 2013 - 09:07:03 AM »
FYI...They do present some fitment issues with larger brakes.
http://www.protouringmopar.com/showthread.php?1307-13-disk-brakes-does-not-fit-a-17-rim
Offline anlauto
« Reply #114 on: December 14, 2013 - 09:25:44 AM »
What about the 12.90 rotor/caliper from Welwood ? http://www.alangallantautomotiverestoration.com/  Will I have issues ?
« Reply #115 on: December 14, 2013 - 09:39:37 AM »
Hummmm  IDK?  :dunno:
Offline anlauto
« Reply #116 on: December 14, 2013 - 09:46:11 AM »
Hummmm  IDK?  :dunno:
The calipers are way smaller then what your using... :dunno:
I'm thinking of the YearOne 17" Magnums, but also wondering about 9"width up front ?
« Reply #117 on: December 14, 2013 - 09:50:41 AM »
Hard to say? The rotors your using are almost an 1" bigger than mine? It should fit but that's only a guess? I doubt a 9" rim will fit even with custom backspacing if everything is stock ( fenders etc...) but I don't know for sure.
Offline anlauto
« Reply #118 on: December 14, 2013 - 09:53:46 AM »
Well how wide are the rims in the above pictures ?
« Reply #119 on: December 14, 2013 - 10:01:06 AM »
Not sure on the Cuda? the Challenger has 8" front and 9" back.
