Author Topic: 1 week away from engine fire up after 18 years  (Read 2140 times)
Offline 1970A66D21
  • Livin in Vegas
« on: October 28, 2012 - 05:25:06 PM »
After nearly 18 years of sitting,I will be starting my 340 up next weekend.Waiting for the oil pressure and water temp sending units from Classic Industries. Might be a little loud for the neighbors.Not sure what will be louder,the headers or the Milodon gear drive.I remember my friends telling me they could here the gear drive coming from a block away.The headers had turbo mufflers bolted to them and nothing else. :naughty:
I am a little bit older now so will go with an x-pipe and Flowmaster 40 full exhaust system.As for the gear drive,if it drives me crazy,I will put a timing chain back on the car.
Re: 1 week away from engine fire up after 18 years
« Reply #1 on: October 28, 2012 - 05:39:01 PM »
congrats , probably the closest us guys will come to giving birth!  :lol:
I have a gear drive on my new 451 and... well.... I might be putting on a timing chain over the winter?
« Last Edit: October 30, 2012 - 07:53:58 AM by brads70 »
« Reply #2 on: October 29, 2012 - 09:31:20 PM »
Awesome , I love the first fire ups with new engines  :2thumbs:
Offline 1970A66D21
  • Livin in Vegas
« Reply #3 on: October 30, 2012 - 08:52:38 PM »
I found a gas station close to my house that sells 100 octane gas for $6.99/gal.Going to go with 8 gallons of premium 91 plus 4 gallons of the 100 fuel.My engine has the stock 10.5 CR though I did go with forged pistons years ago.What does every body think?
« Last Edit: October 30, 2012 - 10:44:23 PM by 1970A66D21 »
Offline Skunkworks Challenger
  • Mopars forever!
« Reply #4 on: October 30, 2012 - 08:58:32 PM »
Quote
Going to go with 8 gallons of premium 91 plus 40 gallons of the 100 fuel.
First fire up sounds exciting!  You sure have a big gas tank.
The Brewmaster
Offline 1970A66D21
  • Livin in Vegas
« Reply #5 on: October 30, 2012 - 10:45:47 PM »
Good catch Skunkworks Challenger.Been corrected.Thanks.
« Reply #6 on: October 31, 2012 - 12:04:24 AM »
read my fire up proceedure in the archives too
Offline Perry
« Reply #7 on: October 31, 2012 - 12:28:56 AM »
I read through that Chryco as I am getting ready for my first fire. You say you don't like pre-oiling to protect the cam lube. Does that mean priming?
Perry
« Reply #8 on: October 31, 2012 - 09:52:12 AM »
If the engine is assembled with Red brg guard it will protect the engine until the oil gets there . if you are going to pre-lube the engine I do not rotate it so the rocker shafts will not get oil but at least this way the cam lube is not wiped off by the lifters before the engine is fired up . keep in mind the cam has no oil feed until it splashes up to the cam off the crank
Offline cudabeforeIdie
« Reply #9 on: October 31, 2012 - 10:53:50 AM »
Thanks... just spit coffee all over my laptop....
Offline 73EStroker
« Reply #10 on: October 31, 2012 - 07:04:11 PM »
If this is a new cam please heed what CP says. Get that RPM up to 1800-2000 instantly. So what I did is install an inhose block heater which we turned on a few hours before firing her up. Made the jump to 2000 on a warm engine. Do that every spring - plug her in. Also we removed the inner valve springs for first start then installed them using the compressed air method to hold the valves shut. Tedious but way better than picking bits of metal out of the engine and a cam change.
Welcome back!
Barry (Salmon Arm)
Offline HP_Cuda
  • Mopar or No Car!
« Reply #11 on: October 31, 2012 - 07:26:32 PM »
Not a roller cam problem. I did look at a pretty cool engine break in stand for $1400 bucks with my machinist. Man it's tempting....
Welcome back!
Offline 1970A66D21
  • Livin in Vegas
Its ALIVE
« Reply #12 on: November 03, 2012 - 03:47:59 PM »
 :bigsmile:The engine started right up once the fuel made its way to the carb.I forgot what the Comp Cams .480 lift 280/280 duration sounds like.Perfect.Little loud and smelly.My boys rooms are above the garage.Can not run it too long.Can't push it outside.The driveway slopes down and is short.Also the HOA would have a field day.Time for a full exhaust.
« Reply #13 on: November 03, 2012 - 06:47:59 PM »
 :2thumbs:
 Congrats , did you at least get the 20 min break in for the cam or is it a roller ?
Offline 1970A66D21
  • Livin in Vegas
« Reply #14 on: November 03, 2012 - 07:34:00 PM »
Engine was rebuilt 22 years ago ,less than 750 miles put on it then parked for almost 18 years.Cam should have broke in years ago.it is not a roller.
