I did find some, just not sure they will fit in the small hole of the mag, but they are on order so I can try. One set from Pro-Comp and another from Cragar. If that doesn't work I will just return the wheels, keep the tires, order the Year One 17" Rallys and use my stock lug nuts. I will do most anything not to have to disassemble and pull brake drums, rotors, calipers, etc. and buy special equipment I don't have to reseat the studs, pull the drums, etc.
