I'm getting a vibration between 3100 and 3600 RPM's when I run the car hard.
Here's the specs:
340 stroked to 416 and internally balanced by Shady Dell Speed Shop
A833 just rebuilt by Jamie Passon with 3.09 1st gear
New McLeod (Borg Beck) clutch set from Passon
Denny's Driveshaft made to fit - all new yokes and u-joints
3.23 Sure Grip with new chrome moly yoke from Denny's
New OEM style motor and trans mounts (insulators), but they are the $10 parts store type
Original crossmember (it's old)
First off, when I run the car easily or at highway speeds there is little or no vibration. So let's focus on when I'm running it hard.
The vibe is hardly noticable in first, a little worse in second, and VERY noticable in third. By the time I hit fourth I'm usually not accelerating that hard so it's not an issue. Again, at highway speeds with low load it's smooth.
I don't notice it when the engine is revved, with or without the clutch out. It's not the clutch set or trans, as I just replaced both and the vibe hasn't changed, or if it did it was very slight. Vibe was there with previous A833 close ratio trans and McLeod Street Pro Kit (which slipped so I junked it).
I spoke to Ryan Johnson at Shady Dell and he suggested that it may be alignment related, particularly the trans mount.
Any help would be appreciated. I'm thinking maybe the crossmember is off center, although it fits easily into place with the four bolts to the body.
