Author Topic: Heater water valve placement  (Read 1299 times)
Offline Fern
« on: October 31, 2012 - 04:04:42 PM »
I have an ac challenger with a/c. I'm trying to locate where on the fender this mounts and which bracket to use. I also need to know where the cable from the hot/cold lever goes through the firewall .
Can someone with this installed take a picture of it in is proper place.
Thank you.
Offline magicr
Re: Heater water valve placement
« Reply #1 on: October 31, 2012 - 05:09:54 PM »
Not sure if they changed locations from year to year but here is where mine is, 1973 Challenger. i would take picture of where cable goes but its hard to see. It goes under power brake booster. Hope that helps
1973 Challenger Rallye
1971 Dart Swinger (sons)
Offline magicr
« Reply #2 on: October 31, 2012 - 05:35:32 PM »
Holy cow, I guess I better clean my engine compartment.   :-[
Offline swede-cuda
« Reply #3 on: November 01, 2012 - 03:58:17 PM »
 :wave: .hej. i got those 2 brackets with my nos heater valve to,but they are not what yoy need.Bill Rolik enterpises,BRE has a copy of the oem bracket that fits like a glove,its nothing like those 2 brackets in your pick. get it. on my -70 cuda the cable comes out of the same grommet that the vacuum supply goes through.that grommet is on the passenger side of the car,its mounted with 3 screws.so ..if you have 2 holes in that grommet the cable should probably pass through it.if only 1 hole in that grommet, then it should probably pass through the fire wall at the mc, and your cable should have a thin plastic grommet/christmas tree on it where it enters thru a tiny hole in the fire wall.  :popcorn: did that help?
Offline Fern
« Reply #4 on: November 02, 2012 - 06:13:46 PM »
Thanks for the info guys, that's exactly what I needed to know. :thumbsup:
Offline chaps70rt
  • 70 Challenger R/T Hardtop in Progress (Canada)
« Reply #5 on: October 11, 2015 - 08:52:21 AM »
Thanks Guys ..... this has been a mystery as the brackets on ebay are incorrect.   Now resolved.
White 1970 Challenger R/T
440 - 4BBL - Shaker
Daily Driver - 2014 Dodge RAM 1500
Stouffville, Ontario Canada
« Reply #6 on: October 11, 2015 - 10:07:48 AM »
:eek4:
Yup, wouldn't hurt...lol  :bigsmile:
Offline anlauto
« Reply #7 on: October 11, 2015 - 10:23:07 AM »
The inner apron should have dimples where you need to drill the holes once you have the correct bracket. :2cents:
