I just installed the Ride Tech non adustable shocks this week-end.
What a pain!
1. The upper bushing has a steel sleeve in it. Included with the shocks are aluminum bushings.
You have to cut out the steel sleeve without injuring the poly bushing.
2. Then I had to "shave down" the aluminum bushings so that the thickness would fit up under inside the shock tower.
So what they're doing is, selling a universal type deal and making it a DIY "you fix the issue"
