Author Topic: stage 6 heads  (Read 1978 times)
Offline OUTRUNM
stage 6 heads
« on: November 02, 2012 - 05:28:23 PM »
I found a set stage 6 heads that have been surfaced and intake seat repaired  68cc standard port size straight plug .. the guy wants $1000 is this a good or bad deal?
1973 BARRACUDA
2006 SALEEN MUSTANG
2006 MONTE CARLO SS
1999 CHEVY PU
1976 PORSCHE 911 S 3.4 RS
1929 FORD MODEL A
Re: stage 6 heads
« Reply #1 on: November 02, 2012 - 05:52:22 PM »
Do You have a picture? Does it have the stock length valves or longer? Stock rocker gear?   There were a few versions of this head is why I ask. I used them in my 451" build . Working great so far!
I made this thread about them when I was researching them and then building them up?
http://www.cuda-challenger.com/cc/index.php?topic=63063.0
and here is my 451" build?
http://www.cuda-challenger.com/cc/index.php?topic=78386.0
Offline OUTRUNM
Re: stage 6 heads
« Reply #2 on: November 02, 2012 - 06:12:32 PM »
1973 BARRACUDA
2006 SALEEN MUSTANG
2006 MONTE CARLO SS
1999 CHEVY PU
1929 FORD MODEL A
Re: stage 6 heads
« Reply #3 on: November 02, 2012 - 06:39:53 PM »
If they have been repaired right then Its an ok deal I guess. I can't quite tell but looking at the springs if they have been sunk into the head about 1/2" then they are set up for stock valves. Mine I bought as a raw casting and I finished them. If you use longer than stock valves and coresponding valve spring depth pockets then that allows you to take/port at least .150" off the roof ( making the ports taller)  which really picks up the flow.
The other reason I like these heads on a "B" block is that it allows you to use a 440 intake. Which will give you a little more volume and more intake choices.  The ports have a ton of material in them so you can port them like you need.  I raised my exhaust ports .150 as the gasket allowed .
The add says it include spacers, so I assume the valley tray is for a "RB" block . When you use these heads on a 440 then you need the spacers.
I'd ask what dia valve stems? I assume stock 3/8" = heavy as compared to 11/32 valve stems = lighter
See if he will send you a picture with a better view of the valve springs? Also what valve springs did he use? Might work for you intended useage? maybe not?
What was "repaired" did a valve seat need to be changed?
Hope that helps? :wave:
« Last Edit: November 02, 2012 - 06:41:48 PM by brads70 »
Re: stage 6 heads
« Reply #4 on: November 02, 2012 - 06:44:49 PM »
I forgot the most important thing.... ask for a picture of the casting mark ( between the valves) . Ask if it's the early or late casting? if it's the earlier casting walk away as they are reported to have porosity issues?
Offline OUTRUNM
Re: stage 6 heads
« Reply #5 on: November 02, 2012 - 08:18:10 PM »
thanks for the info . texted him a while ago weighting to here back
1973 BARRACUDA
2006 SALEEN MUSTANG
2006 MONTE CARLO SS
1999 CHEVY PU
1929 FORD MODEL A
