Author Topic: Can I remove and replace my 340 crankshaft without pulling the motor?  (Read 747 times)
Offline 72CustomCuda
Subject says it all...anyone done it that way?
Re: Can I remove and replace my 340 crankshaft without pulling the motor?
« Reply #1 on: November 03, 2012 - 08:54:08 PM »
I suppose it could be done , the big problem is getting to all the rod caps & getting them out of the way ., not so bad coming out but going back in would be very difficult , you would have to hold a 75 lb crank up while positioning the rods so the crank could be held up with the caps . It would be easier if the heads were off so the pistons could be removed & then re-installed after the crank is in place .
Offline Challenger6pak
« Reply #2 on: November 03, 2012 - 09:32:24 PM »
yes.  It can be done.  I have done it, when I was young and crazy.  Trust me, it is far better to pull the motor and replace the crank on a engine stand.
Offline vinb
« Reply #3 on: November 04, 2012 - 06:37:20 PM »
Pull the engine out,  1 to 1 1/2 hrs and it could be on the engine stand.
You don't what to do bottom end work on your back,  you will be cursing up a storm..
That way you can clean and paint it too...
