I needed to remove my trans cooling lines, and then with the gearbox loosened, I was able to finally slip it into position on the drivers side. The passenger side went in easy, but its nearly impossible to access the bolts to tighten it up!
I got them in with my fingers, but I'll be damned if I can get a wrench in there to tighten them up.... I'll try to finish up tonight.
Now I just need to get this thing wired up to the battery and fill the fluids....
