Author Topic: wont start..........again  (Read 3236 times)
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« on: November 06, 2012 - 12:17:21 AM »
So my 73 340 chally wouldnt start sometimes, turn the key and nothing at all.  Replaced my ballast resistor and it started.  Next time i tried to start it it wouldnt start, completely dead.  Put in a new ignition control module and it started.  The next time i tried to start it it was dead, again.  Jumped the started relay and it starts, so i put in a new relay.....still doesnt start, acts completely dead.  WTF?
 :working:
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline footin70rt
Re: wont start..........again
« Reply #1 on: November 06, 2012 - 12:30:44 AM »
If you have no or limited power in the car I would check the bulkhead connector and see if the main power leads going through are burned, melted, or have green corrosion on them. Very common on these older Chrysler products.
This is some good info on the problem, I did this with mine.
http://madelectrical.com/electricaltech/amp-gauges.shtml
Thomas
Driving the same 70 R/T since October 1985
Native of Bozeman, MT
Offline Kapteenikosmos
« Reply #2 on: November 06, 2012 - 03:59:55 AM »
No start means that the starter motor does not spin from the ignition key but does spin from jumping the starter relay terminals? If so, then I would be looking at neutral safety switch first.  On my Ram Van that has been acting for 3 years no. Some times it does not spin the starter and it works after some furious banging of the gear change lever.
Ville
1967 six banger Mustang
1973 Challenger (under restoration)
1997 Lincoln Mark VIII LSC (daily driver)
Offline 72cudamaan
« Reply #3 on: November 06, 2012 - 08:43:51 AM »
Sure sounds like a bad connection. Every time you move wiring to change a component
it starts right up.  :dunno:
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #4 on: November 06, 2012 - 08:47:36 AM »
Both previous statements are accurate, I would start by simply checking for power on the yellow wire at the starter relay when the ignition switch is in the start position, if no power you know there is a poor connection to track down in the harness or switch. Check for ground on the brown wire at the starter relay, if no ground you have a bad connection or issue with the neutral safely switch, you can make a temporary ground to bypass the NSS to help prove/disprove if that's where the problem lay.
Offline shadango
« Reply #5 on: November 26, 2012 - 01:11:39 PM »
So my 73 340 chally wouldnt start sometimes, turn the key and nothing at all. .....still doesnt start, acts completely dead.  WTF?
 :working:
Define "nothing at all".
Does the fuel gauge come up and the e-brake light come on when you twist the key?  If not , read on:
I had an intermmitant no start on mine ....tried a bunch of things and then I noticed the gas gauge wasnt coming up......brake lights werent coming on on the dash...ie no power.
Replaced the starter switch, sure that that was it..... and that didnt help.
Turns out that the aftermarket p.o.s. replacement lock tumbler/mechanism was malfunctioning.....and wasnt triggering the starter switch correctly.
Well, replaced the lock assembly with one from a salvaged column sitting in my shed and viola..no problems since.
I have to carry around THREE keys (one ignition, one locks, one trunk) but I am OK with that.  I could get the ignition keyed the same as the door locks but I do not want to mess with it anymore... getting the column apart is not HARD, but its a bit of a PITA.
Offline Sleepychallenger
« Reply #6 on: November 26, 2012 - 04:30:05 PM »
I had my starter wires come loose off the starter at one point and gave me the same problem. Didnt know it till it was dark and i saw some sparking. May wanna check your wire connections on the starter.
Offline 06Daytona
« Reply #7 on: November 29, 2012 - 07:12:06 AM »
I've been having the same problem with my Challenger since it came back from the trans shop. Found your thread last night while I was looking for something else so I decided to try jumping the NSS to the battery ground. Fired up right away. I'd recommend trying that.
1972 Cuda 340 4 barrel 4 speed that looks like a 71
2006 Dodge Charger R/T Daytona
2005 Dodge Ram 2500 Diesel 4X4
2006 Chrysler PT Cruiser Convertible (Kidmobile)
1972 Dodge Charger 318 auto
1970 Challenger 440/727 auto
1973 Plymouth Duster 340/auto (Making it Panther Pink for the wife)
2006 Honda Civic Hybrid (It doesn't save gas, it just diverts it to the Cuda/Challenger)
In desperate need of more property for my growing Mopar family
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #8 on: December 22, 2012 - 10:09:10 PM »
if its not the neutral switch or bulk head connection it could be some weak grounds , there are plenty of areas that need good ground to start the car
72rtchallenger
what happens in the garage
stays in the garage
Offline 74challenger03
« Reply #9 on: December 23, 2012 - 08:30:05 AM »
 :popcorn:
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #10 on: December 23, 2012 - 05:32:14 PM »
Thanks for all the great tips and advice guys!  Turned out to be the ignition switch in the column! :2thumbs:
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
Offline shadango
« Reply #11 on: December 24, 2012 - 07:40:26 AM »
Glad you found it....
Was it the electrical part or the key part???
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #12 on: December 24, 2012 - 10:02:57 AM »
The electrical part
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
