Author Topic: Power Steering Testing  (Read 636 times)
Offline Mopar_Mudder
  • I'm a llama!
« on: November 07, 2012 - 10:39:37 AM »
Got a question on testing out power steering before it is all in the car. Right now I have everything mounted to the K-Frame with the motor sitting on the stand. It is a new Fedral pump and I rebuilt the steering box. I filled the pump with fluid and I am using a drill to spin the pump.
First question is how hard should the pump spin, it really drags a 3/8 drill down. If that is normal I can see where they rob horse power
Next how can I tell if I am getting the correct power assist. Turning the shaft that the steering wheel hooks to with my fingers it doesn't seem to turn any harder or easier when spinning the pump or not.
I assume it is some what working because at first the shaft would turn by itself. After centering the valve assembly it stays put now, by the way it take very little movement of the valve body to adjsut that, very tuchy.
Just alot easier to get this all squared away before it is in the car if possible.
1971 Hemi Cuda
2005 SRT-10 Regular Cab Flame Red.   12.771 @ 109.67 <-----Time Slip --Video
Mopar: Headers, Exhaust, Ram Air, ECM
2008 3500 Mega Cab Dually, Resistal Edition
Re: Power Steering Testing
« Reply #1 on: November 07, 2012 - 10:50:59 AM »
I have never tried that , I would assume the pump would stall a 3/8 drill
