Author Topic: Steering is out of control  (Read 1545 times)
Offline Cdnchallenger
« on: November 07, 2012 - 12:55:35 PM »
Hi,
Trying to get my car back together. I have power steering that is really loose. It takes no effort at all to turn in a circle with as little as one finger.
I do not feel comfortable driving the car as it is now. I need it to be a lot tighter.
Sorry i know very little about the steering. Any suggestions as to what I should be looking at?
Thanks in advance,
Steve
Re: Steering is out of control
« Reply #1 on: November 07, 2012 - 01:23:41 PM »
That is completely normal.  One of my fond memories as a child is being in the passengers seat watching my dad steer the car with one finger.  If all steering components are tight, then you'll have to look into a Firm Feel box.  They have three different stages.  Just from reading peoples impressions with the different stages, you'll want a stage 2 at minimum.
Also, when you're looking over the steering components, make sure to check the welds on the k-member.  The factory welds were awful and the mounts have been known to break.
Offline Jamiez
  • Retro
« Reply #2 on: November 07, 2012 - 01:47:51 PM »
As burdar said, that's normal.  However if you've only driven modern cars you probably don't like the feel.
This article tells you how to adjust the feel.
www.moparaction.com/Tech/beep/PUMP_IT_DOWN-re-v1.4.pdf
« Reply #3 on: November 07, 2012 - 02:03:25 PM »
Great article!  I might have to try that if I don't get used to the way the car drives right now. :thumbsup:
Offline Jamiez
  • Retro
« Reply #4 on: November 07, 2012 - 02:22:39 PM »
I can't take credit for it :)  I just saved it from _Russ_'s power steering pump rebuild thread :)
« Reply #5 on: November 07, 2012 - 04:08:45 PM »
Welcome to Mopar slush box steering. :lol:  Mine was so bad I'd turn about an 1/8 of a turn either way before anything happened.  So it wasen't just a matter of slowing down the pump pressure the box was plain wore out ( leaked too) I know it's expencive but do yourself a favour and get a firm feel box stage 2 or 3. I went for a stage 3 and really like it. That combined with the fast ratio arms makes for a really nice steering car!  :2thumbs:
Be aware there are 2 sizes of sector shafts in stering boxes.  I used the big one 73-74 as I hear parts are cheaper and more plentiful?
Offline shadango
« Reply #6 on: November 27, 2012 - 09:19:50 AM »
 :iagree:   WONDERFUL upgrade.
« Reply #7 on: November 27, 2012 - 09:47:30 AM »
Mopar power steering was over engineered , No feel LOL  I agree with a firm feel stage 2 minumum box .
Having a proper wheel alignment helps a lot as well , there were no radial tires in 69 so the specs are for bias ply , max the caster , set the camber 1/2 -1 * in at the top & 1/16 of toe in & it will help a lot .
