Author Topic: 440 Six Pack - Vacuum Signal Question ....  (Read 482 times)
Offline 72ls5fla
« on: November 07, 2012 - 11:44:02 PM »
hey ...
Just a quick question ...
If I were to disconnect the vacuum source to the end carbs, would that prevent them from opening while driving?
I was just trying to figure a way to maybe bump up the highway MPG when going for a long distance run.
I recently ran the car on two trips, both were around 200 miles one way.  I got right around 11.5 MPG running 70 MPH, with 3.54 gears.
Are there any dangers in removing vacuum source?
Thanks
Bill
Re: 440 Six Pack - Vacuum Signal Question ....
« Reply #1 on: November 08, 2012 - 07:04:45 AM »
well it will open a vacuum source into the venturi of the center carb so you might want to plug it instead . , it might increase the ,milage a little depending how you drive , the milage seems low to me but you are revving fairly high with 3.5 gears
