Author Topic: A518 BB Adaotor plate vs bell housing  (Read 1619 times)
Offline ff6849
« on: November 11, 2012 - 06:15:12 PM »
When installing an A518 behind a 440 which is the better option, the adaptor plate or splicing on new bell housing, I have a friend who is a pretty savvy transmission guy, he thinks it cutting off the old housing and bolting on a different bell housing creates a potential for leaks and weakens the case. He prefers using the adaptor plate what do you all think, or should I get new friend  :screwy:
And why does the adaptor plate cost so dang much.
(__________]]]]]}~~~~
73 440 Cuda'
915 heads (mild head work, stock bottom end 10/9:1 compression)
A518 2600-2800 Stall
4.10 rear gear
TTI headers with 3' exhaust with  X pipe
comp XE274H cam
Hughes Roller Rockers
Holley Sniper EFI
Holley Street Dominator intake
MSD ignition
Offline ff6849
Re: A518 BB Adaotor plate vs bell housing
« Reply #1 on: November 15, 2012 - 01:54:03 PM »
No one has an opinion on this :clueless:
73 440 Cuda'
4.10 rear gear
comp XE274H cam
Holley Sniper EFI
MSD ignition
Offline Aussie Challenger
« Reply #2 on: November 17, 2012 - 04:23:25 AM »
Unfortunately there won't be many adapters made, they take a bit of work to make and set up to be accurate therefore cost more. I read somewhere that a bell-housing was adapted to an A518 but cannot find it, bolted up to the pump housing from memory.
Offline ff6849
« Reply #3 on: November 17, 2012 - 08:42:27 AM »
that's my concern that they do bolt to the pump housing, putting stresses on something that wasn't design to take that type of stress.
73 440 Cuda'
4.10 rear gear
comp XE274H cam
Holley Sniper EFI
MSD ignition
« Reply #4 on: November 17, 2012 - 12:41:23 PM »
an adapter plate if availble should be ok , usually they are 1" or less thick & allow the trans to bolt onto the plate & block which is basiaclly a very strong design overall
