Author Topic: Another oil question  (Read 912 times)
Offline 70 RAG TOP
« on: November 11, 2012 - 09:05:50 PM »
I ve read somewhere in this forum that you should not use synthetic oil in a newly rebuilt engine until it has about 6000 miles on it.  I am at 500 miles and I am going to drain out the break in oil( comp cams 10w30 break in oil) and put in fresh oil and filter.  I had decided to go with the Brad Penn oil until I saw that it was a "synthetic blend".
My question is: is syn blend ok to use or does it need to be straight conventional oil?
Thanks
Offline oldkimmer
Re: Another oil question
« Reply #1 on: November 11, 2012 - 09:10:09 PM »
..........I would run the dino oil this time then switch over.........mosty syn blend is only about 10-20% anywayus.........kim....
The beast has been unleashed........Thems the hazzards..........Unleash the beast......
« Reply #2 on: November 11, 2012 - 09:12:00 PM »
I agree run a non syn but with high zddp or additive to keep the cam alive
Offline 70 RAG TOP
« Reply #3 on: November 12, 2012 - 09:42:12 PM »
Can you  give me some suggestions of a good conventional oil with high zinc/phos.
Thanks
« Reply #4 on: November 12, 2012 - 10:54:19 PM »
I would just get Castrol 10-40 & add Cam Saver or Comp cams additive
Offline 70 RAG TOP
« Reply #5 on: November 12, 2012 - 11:14:48 PM »
Thanks, I'll go with the Castrol and the additive.
Offline 72cudamaan
« Reply #6 on: November 12, 2012 - 11:50:52 PM »
If you're sure the rings are seated ( if honed properly they are) then you could go ahead
and use synthetic oil. The only reason to not use synthetic is so that the rings will sufficiently
scuff on the cylinder walls and seat.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline 70 RAG TOP
« Reply #7 on: November 13, 2012 - 12:16:49 AM »
Is 500 miles usually enough enough to break in engine or should I keep the comp cams break in oil in a little longer?  I assume the machine shop honed the cylinders properly but can't be sure.
Thanks
« Reply #8 on: November 13, 2012 - 07:43:48 AM »
I would run it longer with non synthetic , once the synthetic is in there you cannot go back to non syn & seat the rings in further
Offline 72cudamaan
« Reply #9 on: November 13, 2012 - 08:34:47 AM »
:iagree: If you don't know what kind of equipment was used to finish the cylinders then you may as
well wait until your first maintenance oil change. Neil is right, you can't go back to traditional oil and
potentially fix an oil consumption problem. I know that with the equipment I was using, by the time you had rotated
 the engine enough to install pistons and adjust the lifters, the rings were seated.
