Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
Turn signal cam only repalcement, will this work?
« previous
next »
Print
Pages: [
1
Author
Topic: Turn signal cam only repalcement, will this work? (Read 924 times)
KillerBee
Jr. Member
on:
November 14, 2012 - 03:23:29 PM »
Getting parts together to replace my broken turn signal cam, won't hold in up position but everything seems to work fine and wiring looks good.
From reading older posts here the Standard TW7 is the correct complete turn signal switch replacement, but the cheapest I've found it is $70 at Rock Auto.
It appears Dorman sells just the cam that can be cut and soldered into the switch wiring under the can for much less.
http://www.jegs.com/i/Dorman-Products/326/49301/10002/-1?parentProductId=1532093
Will this work?
How difficult is it to remove the old turn signal cam?
Last Edit: November 14, 2012 - 03:25:26 PM by KillerBee
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Turn signal cam only repalcement, will this work?
Reply #1 on:
November 14, 2012 - 06:19:23 PM »
not hard to change , you do have to cut & solder the two wires , mixed results but worth a try
Logged
don340-4
Jr. Member
Reply #2 on:
January 14, 2013 - 11:40:04 PM »
Didn't work for me, contacts are not reliable, I ended up just buying the complete harness & switch from Year One licensed Chrysler restoration part, works perfect now.
Logged
Don
1970 Challenger R/T SE
1970 Challenger Western Sport Special
1969 Plymouth Road Runner
2012 Ram 1500 R/T
CHL2T
Full Member
Handle it, man!
Reply #3 on:
January 22, 2013 - 03:05:07 PM »
I had to file the contacts to get the dorman to work in the Charger and Challenger other than that a pretty straight forward swap
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
