Author Topic: Drive shaft orientation  (Read 1306 times)
Offline tony 73
« on: November 20, 2012 - 02:44:33 PM »
Am about to get my driveshaft shortened. When i looked at my friends in his 70 383/727, the stepped down section of the drive shaft was at the diff end of the shaft. On mine , 318/904, the step down is at the trans end. Is there a right and wrong way ? I have seen a pic of Burder's driveshaft (pg 15 resto) and his has the step at the trans end. I have to shorten mine by about 3 1/2 inchs. If we took this out of the trans end we would nearly lose the narrow stepped section.
Re: Drive shaft orientation
« Reply #1 on: November 20, 2012 - 03:05:32 PM »
The stepped section is toward the rear.  That's now mine is...step back at the rear end.
« Reply #2 on: November 20, 2012 - 06:04:08 PM »
 :iagree:, I have usually seen the tapered small end at the diff
Offline tony 73
« Reply #3 on: November 20, 2012 - 06:19:28 PM »
Thanks for the info darren and Neil. I will double check and then my see if we can get the taped end at the diff.
