Author Topic: Duff's - 1971 'Cuda 383 4spd B5 Blue  (Read 51090 times)
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
Re: Duff's - 1971 'Cuda 383 4spd B5 Blue
« Reply #105 on: October 07, 2013 - 07:46:42 PM »
Your making great progress duff!
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline Duff
« Reply #106 on: October 08, 2013 - 11:05:25 AM »
Thanks guys!  Shooting some epoxy primer tonight, actually...  :bananasmi
Offline Duff
« Reply #107 on: October 09, 2013 - 11:18:15 AM »
Work, work, work...
Got the left side dropoff, outer wheelhouse, and quarter welded on & roughed in.  Also ripped apart my k member to change the bushings and paint up.
« Reply #108 on: October 09, 2013 - 12:12:08 PM »
Work, work, work...
 I think Chrysler employed drunk welders back in the day!  ::)  Might want to take this opportunity to reweld the k-frame and gusset the steering box mounts? Look at firm feels web site for some pictures?
http://www.firmfeel.com/reinfkfram_e.htm
Offline anlauto
« Reply #109 on: October 09, 2013 - 12:16:22 PM »
What about the rust under the rear window and windshield ? Goning to be a real bugger when it start to bleed out under your fresh paint.
Offline Duff
« Reply #110 on: October 09, 2013 - 03:14:24 PM »
You're right Brad, thanks for the suggestion.  I'll definitely do that.
@anlauto - you're very right and thanks for the headsup.  I plan on taking out the front & rear windows and cleaning up everything before doing the primer on the body
Offline anlauto
« Reply #111 on: October 09, 2013 - 04:37:53 PM »
Well if that is the plan, then in my opinion the glass should have come out a long time ago to protect it from , sand blasting, weld sparks grinding sparks, sanding marks etc... :2cents:
Offline Duff
« Reply #112 on: October 16, 2013 - 02:36:01 PM »
Engine dyno yesterday :
1971 Cuba 383 dyno
got just over 330 horsepower and 393 torque.  Used a Bob Karkashian (mr6pack) cam recommended by CODY.  Overall for a pretty much stock-ish build i'm pretty happy I think.  Paid $428 for a full 7 hours of tuning and 3 guys working on setting things up and making changes.
Stock carb had a small issue because the vacuum secondary diaphram on the List 6191 carb (stock for 71 383 4 speed) was bad, and the one that came with my big $100 kit (part number 37-1536) had an eyelet on the end of the rod instead of an elbow.  Contacted holley and found out that the elbow was a chrysler only thing and is only available through Daytona Carburetors in florida.  Also I needed a banjo style fitting for the fuel inlet (part number 26-25).  Got them both shipped to me from daytona for $37 total.  Not a remarkable deal, but at least they're coming.  THe part number for the diaphram is 64-707a just for the record.
The other interesting info about the dyno was that the stock carb was performing comparably with a new style 80670 (with jets 69p and 72sec working the best), though the newer carb had slighly smoother torque and hp curves through the runs (could've been the vacuum secondary diaphram that we rigged in).  In addition to this, we found that a spacer added like 7 hp.  I think i'll try and just get a thicker gasket though instead of jumping to a 1" spacer right away.
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #113 on: October 17, 2013 - 04:51:51 PM »
 :woo:
Offline Cuda Cody
  • Vancouver, WA
« Reply #114 on: October 17, 2013 - 05:59:46 PM »
That turned out real strong!  Time to get her in some paint and ready for her big date with the engine bay.   :clapping:
Offline Duff
« Reply #115 on: October 17, 2013 - 07:28:51 PM »
A few more pics.  Took my rear window out and started cleaning up the lower rust area.  My guess is the window's never been out until now.  also cleaned up the lower quarters where the valence mounts.  My quarters weren't amd and weren't really made to just have the valence plopped in, so I had to do some metal work/body work to get them nice to where it'd look right.  some body work on the inner fender aprons also and some work on the tail panel and licence plate area.
Offline Duff
« Reply #116 on: October 17, 2013 - 07:29:38 PM »
rear window pic.
Offline anlauto
« Reply #117 on: October 17, 2013 - 07:52:33 PM »
Ahhhh...finally, now I can get some sleep..... :smilielol:
I knew you'd find rust under there :thumbsup:
Offline Duff
« Reply #118 on: October 21, 2013 - 04:12:53 PM »
I'm trying to figure out what the correct fuel pump to Carb tubing is for my 383 4 speed with a holley 6191.  The best info i've come up with is that there's a brass fitting that goes into the carb which connects to possibly this descriptionless product, which I understand to be a prebent tube for all 383 and 440 4 barrel applications:
http://www.classictube.com/shop-online?page=shop.product_details&flypage=flypage.tpl&product_id=9521&category_id=938&keyword=cyc1010
Can anyone verify this?  I'm having trouble finding any pictures or references on this, though I haven't yet checked my service manuals.
Offline anlauto
« Reply #119 on: October 21, 2013 - 04:26:35 PM »
Surprized you have a Holley, must be an early build 71.
I would go with the 70 383 2 pc kit if you want a fuel filter in after the pump, or they do have a one piece for no filter.
I don't know about the other guys, but I only deal with Fine Lines http://finelinesinc.com/catalog/index.php?cPath=278_461&sort=2a&page=1
