Author Topic: Duff's - 1971 'Cuda 383 4spd B5 Blue  (Read 51072 times)
Offline anlauto
Re: Duff's - 1971 'Cuda 383 4spd B5 Blue
« Reply #180 on: December 12, 2013 - 05:04:29 PM »
What type of clutch ?
Offline crocha617
« Reply #181 on: December 13, 2013 - 01:41:44 PM »
Yes the type of clutch determines whether you use the large over center spring in the clutch pedal assembly or not. I'm assuming your spring is in place now & you installed a diaphragm style clutch.
« Last Edit: December 13, 2013 - 01:52:10 PM by crocha617 »
Offline Duff
« Reply #182 on: December 17, 2013 - 05:03:10 PM »
 :banghead:
I really have no clue on this one.  Beyond my skillset.  Does this pic help identify it?
The only spring I have in the installation is the return spring on the outside of the fork.
« Last Edit: December 17, 2013 - 05:48:26 PM by Duff »
Offline anlauto
« Reply #183 on: December 17, 2013 - 05:12:50 PM »
That's a diaphragm type clutch you need to remove the large over center spring off of the clutch pedal if you haven't already.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #184 on: December 18, 2013 - 01:07:50 PM »
Remove the big daddy spring on the clutch pedal assembly, the downside is that you will have play at the top of the clutch because the diaphragm will not hold the clutch all the way up.
Offline Duff
« Reply #185 on: December 18, 2013 - 01:37:10 PM »
What would be the stock way to do this?  Should I switch this out? I would have to pull everything apart I think...
Offline anlauto
« Reply #186 on: December 18, 2013 - 01:59:35 PM »
You'll have no problem with that clutch, just remove the big spring. I just did this last month with a 440 in a 71 Cuda :2thumbs:
Offline Duff
« Reply #187 on: December 18, 2013 - 02:33:27 PM »
cool, i'll do just that.  Thanks for your help guys.
Offline crocha617
« Reply #188 on: December 18, 2013 - 03:02:05 PM »
Stick a screwdriver between the coils and jamb some washers or coins between all the coils of the spring one by one. That will lengthen it and make it easier to get out. OR just cut it and throw it away if you can get something up there to cut it out.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #189 on: December 18, 2013 - 03:06:49 PM »
Alan
Once you pulled it, how much play was in the pedal?
B
Offline anlauto
« Reply #190 on: December 18, 2013 - 03:31:36 PM »
You have to keep the small spring on the clutch fork. There's regular free play before the clutch disengages
Offline HP_Cuda
  • Mopar or No Car!
« Reply #191 on: December 18, 2013 - 05:55:50 PM »
Clutch fork return spring
http://www.drivinithome.com/wp-content/blogs.dir/3/files/2012/02/clutch.jpg
I still think that lil sucker won't hold the clutch pedal all the way up but I have another plan to make it work.
 :bigsmile:
Offline Duff
« Reply #192 on: December 19, 2013 - 11:17:55 AM »
Stuck two screwdrivers on the end of that spring and had it removed in 2 minutes.  Clutch feels great now!  Thanks again guys for the help on that one.   :bananasmi :bananasmi :bananasmi
Offline crocha617
« Reply #193 on: December 19, 2013 - 11:23:32 AM »
Great!! I struggled with that same situation years ago.
Offline anlauto
« Reply #194 on: December 19, 2013 - 11:52:03 AM »
Bill is in the mail :2thumbs:
