got some assembly work done on my engine this weekend. Foud out the difference between the two water pumps I had is that the -7 is deeper to clear the timing chain cover, so since i only blasted the other one i've gotta now blast the correct one and install it. Still need to buy plug wires, water pump guts, pcv valve, temp sensor, thermostat, oil pressure sensor, heater hose fittings, coil, and air filter. After that's done I hope to have the engine together this week and ready for the dyno.
