Duff's - 1971 'Cuda 383 4spd B5 Blue
Author Topic: Duff's - 1971 'Cuda 383 4spd B5 Blue  (Read 51078 times)
Offline Edison1970
Re: Duff's - 1971 'Cuda 383 4spd B5 Blue
« Reply #210 on: January 20, 2014 - 04:59:15 PM »
I like it the way it is.  I'm sure it will look nice completed but I would drive it as it stands.  That is probably what I am going to do with mine.  I need to save for the paint.
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #211 on: January 20, 2014 - 06:33:54 PM »
Cool, get some pictures along the way. We would love to see it out on ol 66..
Offline Falbz
« Reply #212 on: January 20, 2014 - 07:25:01 PM »
Looking good man - definitely enjoy the drive and you should be proud of where the car stands only after 6 months  :22yikes:
Looking forward to seeing it at Woodley Park  :2thumbs:
« Last Edit: January 20, 2014 - 07:26:36 PM by Falbz »
Offline calicuda70
  • 2 evil 70's and 1 BAD 11
« Reply #213 on: January 21, 2014 - 12:57:34 AM »
Duff what part of Cali you headed to
70 'Cuda 5.7 Hemi protouring resto
70 Challenger 360
11 Challenger SRT8 392
Offline 360FISH
  • BS23H3B567746
« Reply #214 on: January 21, 2014 - 02:11:32 AM »
Holy crap!  Looks great Duff...  was not long ago (at all) that I could see the ground through most of the car...  amazing job!
If you are heading out to Cali in April...  stop at Mopars at the strip on the way...  or at least be here for the Spring Fling.  I'll be at both and I HAVE to see the car.
Congratulations!
Alan
1973 ‘Cuda   Semi-Pro Touring
Offline Duff
« Reply #215 on: January 21, 2014 - 05:11:22 PM »
Thanks guys, but the congratulations came too soon....
 :swear: :stomp: :pullinghair: :banghead: :swear: :stomp: :pullinghair: :pullinghair: :villagers: :villagers:
Did a very small amount of warming up the car, then drove a few miles, then...
Rear main seal leak, and when I turn the car to one side it brakes pretty hard.  OUch.
What I found out:
My prebought Right stuff Detailing front disc brake conversion kit includes two brake lines that go from the caliper to the body connection on the car.  These have about a 2" piece of hard line coming off the banjo connection on the caliper, and that 2" piece hits the a-arm.  In addition to this, both of the brake lines are too short, causing them to pinch when I turn the wheel.  Sure I noticed this when I installed them, but a month after it's easy to forget.  The solution to this (via them on the phone) is to buy 69 camaro front disc brake flex lines and install those instead.  The company is well aware of this problem and apparently still just sells the kits, which sucks for guys like me trying to get to Vegas this weekend...
So, today i'm in the middle of my oil pan and my brake system hacking it out to try and leave cross country in the morning.  Wish me luck!  And yes 360fish, i'll be back in Hollywood in no time, so i'll be at spring fling and hopefully mopars at the strip as well!
Offline E-Body Products
  • E-Body Products
  • American Jobs Are Our Children's Future!
    • E-BODY PRODUCTS
« Reply #216 on: January 21, 2014 - 05:52:09 PM »
Love the way it looks!!!
Daniel
www.ebodyproducts.com
Offline Duff
« Reply #217 on: January 22, 2014 - 10:56:42 AM »
Rear main seal is in!  I was able to find an old school non pipe cleaner style seal from my engine builders buddy and get it installed last night on my back w the car on jackstands. Btw I found out a but too late that 440 source apparently offers this stuff, and knowing what I know now I'd highly recommend using it.  Everything's back together now and I'll test it today... Crossing my fingers.  Then it's my father and I cross country to Vegas then Hollywood!  Woohoo!  One of my dreams comes true today
Offline Dr. Feelgood
  • 1970 Challenger R/T #XXX666
« Reply #218 on: January 22, 2014 - 01:23:30 PM »
 :2thumbs:
Got the same dream but it's from Ontario to Alberta up here lol!
  • E-Body Products
    • E-BODY PRODUCTS
« Reply #219 on: January 22, 2014 - 06:43:21 PM »
Enjoy!!!
Daniel
Offline 360FISH
  • BS23H3B567746
« Reply #220 on: January 22, 2014 - 08:22:14 PM »
:2thumbs:
Maybe a Power Tour next year?    :cooldancing:
Offline Duff
« Reply #221 on: January 28, 2014 - 05:37:19 PM »
Made it back to Hollywood!  The car ran okay but I definitely had some issues...
1.  The car vibrates terribly starting at 70 mph.  I did have the driveshaft balanced and I balanced the wheels myself, so I'm not quite sure what to do to troubleshoot this.  Ideas anyone?
2.  The car gets hot.  Seems to run at the top of the acceptable range, but it's very hot, like the carb is super hot to the touch.  The only part that isn't new or rebuilt in the engine bay is the fan clutch, but it moves.  Not sure if this could be it or not.  Thermostat is obv new also.
3.  The car doesn't start as well, especially when hot.  Sounds like it missing or has a fouled plug or something.  The car does start right away, but it has to get warm to idle, and it's 80 degrees here.
4.  I think the car runs rich.  It was tuned on the dyno in Iowa in a room that was about 55 degrees in the wintertime, and now im at sea level instead of at 1000 ft elevation.  Retune?  I hesitate to because it already was on the dyno, but on the other hand I feel like the carb should be tuned with an o2 sensor in the exhaust maybe.  Thoughts?
Thanks guys!
Offline Cuda Cody
  • Vancouver, WA
« Reply #222 on: January 28, 2014 - 05:40:20 PM »
Sounds like a choke issue.  What choke are you running?
Thanks guys!
Offline anlauto
« Reply #223 on: January 28, 2014 - 05:43:33 PM »
The car was only meant to be driven a 1/4 mile at a time silly :wave:
Offline Colorado-0A5599
  • Mopar or no car!
« Reply #224 on: January 28, 2014 - 06:28:45 PM »
Quote
 I ran Mastercraft Avengers on a 66 Sport Fury. They did not like balancing weights at all.  Another experiance was balance weight on front of driveline.
  Just some historical thoughts.
tc
My wife ?   O.K.
My dog ?    Maybe
My Dodge? NEVER!!!
