Author Topic: Holes at Bottom Corners of Windshield Frame  (Read 1899 times)
Offline 70 MT Chally
« on: November 22, 2012 - 09:39:28 AM »
What are these holes?  Are they normal?  Identical holes are on the other side.
Should I tap them flat and spot weld them?
Thanks,
70 MT Chally
Offline dutch
Re: Holes at Bottom Corners of Windshield Frame
« Reply #1 on: November 22, 2012 - 09:42:55 AM »
I dont recall seeing those
*** Bart ***
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #2 on: November 22, 2012 - 01:30:11 PM »
Can you get an expanded picture of that?
Can't really tell where that picture is?
« Reply #3 on: November 22, 2012 - 06:04:19 PM »
Here is a pic showing that area on bottom of pass window frame...
« Reply #4 on: November 25, 2012 - 08:53:35 PM »
That's where the plastic/rubber spacers go that position the glass properly. I don't recall those holes on my car though.
Offline nr1freak
  • Go catch a 'Cuda, If you can...
« Reply #5 on: November 25, 2012 - 09:16:15 PM »
kinda look like welds that got ripped out of the sheetmetal...
Cuda's don't leak oil, they mark territory...
Offline Skunkworks Challenger
  • Mopars forever!
« Reply #6 on: November 25, 2012 - 09:23:30 PM »
My car had those holes and for what I don't know.  Some assembly aid at the factory probably.   I welded mine shut!
The Brewmaster
Offline shawge
  • Zoiks!!
« Reply #7 on: November 26, 2012 - 12:47:05 PM »
Mine had them as well (LA build).  They looked like a potential leak so I welded them up.
- Jerry
« Reply #8 on: November 26, 2012 - 12:59:09 PM »
Mine is an LA Car, too.
I am grateful for the responses.  I think I am just going to tap them closed and weld them.  They don't seem to serve any purpose.
Thanks again,
70 MT Chally
  • Mopars forever!
« Reply #9 on: November 26, 2012 - 01:25:08 PM »
I'm wondering if it was and LA thing only.  My car is also an LA.  Any none LA cars have the holes?  They look like they were punch from the bottom side with a sharp punch.
The Brewmaster
Offline ksierens
    • 70 Challenger Resurrection
« Reply #10 on: November 26, 2012 - 06:50:48 PM »
Mine had them too, and it was made in Hamtramck  I post the same question a few years ago, and no one knew, so I welded them up also.
Kurt - SE Michigan
Offline ntstlgl1970
  • T a c o c a t
« Reply #11 on: November 26, 2012 - 07:00:49 PM »
had the holes in mine as well  - LA car
