The power adders are years and years away if they ever happen, I only meant it may be easier based on one platform than the other to go that route.
I am aware that CR's, CAM's and a bunch of other things would need to be adjusted when moving to forced induction. But if as an example there are a million kits out there to Supercharge or turbo a modern Hemi v.s. slim pickings to do the same to a stroked 440 it may feed into my decision.
I want to understand my future options as I make this decision. I plan to have this car for a long time and don't think I will ever be "done" with modifying it.
Just looking to get opinions from others who have already "been there done that", my pro's and cons as I see them (not based on any significant facts) are:
Stroked 440 Pro's-have block already
-know it fits without modifications
-know the 5 speed I have my eye on fits without modifications
-FAST EFI can support forced induction
-know I can get the sound I like from it
Cons-Forced induction is likely going to be a custom kit $$
-heavier?
-too many options out there for heads / cams - what to choose? will it all work together?
Modern Hemi SwapPro's-better reliability?
-less mixing and matching of combinations (heads/cams/exhaust)?
-many kits out there to go forced induction (with little internal mods ?)
-better fuel economy?
Con's-transmissions? will it require a transmission which also require modifications to the car?
-fabrication required to install
-hood clearance issues?
-accessory clearance issues?
-more complicated to install (much more electronics)
-haven't heard one sounding like what I want
