Author Topic: What triggers turn signal cancellation?  (Read 3057 times)
Re: What triggers turn signal cancellation?
« Reply #15 on: November 27, 2012 - 09:47:02 PM »
Neil has mentioned it, but it's the large snap ring under the can.  I don't think that's it as it wouldn't work in either direction.  It's worth a closer inspection to be sure while you have the can off anyway.
The snap ring under the can acts on a plastic tang that releases the plastic catch that holds the turn signal switch on. There is one for the left signal and one for the right signal. My money is on the left tang being broken.
Offline Skunkworks Challenger
  • Mopars forever!
« Reply #16 on: November 27, 2012 - 10:22:23 PM »
Maybe this photo will help.  There is only one cancellation post.  It is the coil or snap ring as Neil said.  Sorry for the poor picture--it is a file photo from my restoration.
« Last Edit: November 27, 2012 - 10:25:23 PM by Skunkworks Challenger »
The Brewmaster
Offline Cuda Cody
  • Vancouver, WA
« Reply #17 on: November 29, 2012 - 09:30:47 AM »
Here's some better angle photos of a columns I restored...
Offline Cuda Cody
  • Vancouver, WA
« Reply #18 on: December 02, 2012 - 09:33:55 AM »
Any luck solving the problem?  If you're still having some issues, post a few photos and I'm sure one of us can help you with a solution.  :2thumbs:
Offline swede-cuda
« Reply #19 on: December 02, 2012 - 03:16:58 PM »
 :wave: what if the coiled spring was removed, and when remounted was clocked differently,would that cause this ??
« Reply #20 on: December 02, 2012 - 06:06:58 PM »
yes the the spring was clocked wrong you might have to go 3/4 of a turn or a bit more to cancel
« Reply #21 on: December 07, 2012 - 11:33:51 AM »
Did you find the problem?  :popcorn: :popcorn:
Offline 7Dcuda
« Reply #22 on: December 10, 2012 - 09:31:22 AM »
I did.  Somehow the cancelling "arm" of the turn signal switch for the left side got bent so the spring on the bottom of the crush can wasnt catching it to make it cancel.
