Author Topic: Picture of rear view mirror installed needed!  (Read 1228 times)
Offline 72challenged
« on: November 28, 2012 - 01:16:12 PM »
Picture of rear view mirror installed needed! My car came in boxes and I do not know the orientation of the center rear view mirror mounted, any one have a picture?
Tia, eh
« Last Edit: November 28, 2012 - 02:56:40 PM by 72challenged »
72' Challenger Rallye, Lt Gunmetal Metallic, 360/4, 727, 8 3/4 sure grip, a/c ps pb, Bilsteins,  mini like wheels, BFG 245/60 15's
Thanks to R/T Spec., Year1, Jeg's, Napa Lyndon, Bohn services, Mopar Joe, Bell Motors, paint by Ray, Evans elect., MCB, Totally Stainless, Moparts, FBO, Mike the Car, Firm Feel, Unique Fab,
Offline 74challenger03
Re: Picture of rear view mirror installed needed!
« Reply #1 on: November 28, 2012 - 07:25:35 PM »
one pic is looking up under the mirror
« Reply #2 on: November 28, 2012 - 11:22:21 PM »
thanks alot, that really helps, now if I can find the screw holes under the new headliner!
eh
« Reply #3 on: November 30, 2012 - 07:01:03 AM »
had the same problem when i bought my car,new headliner but no mirror. Talk about freaked out in putting holes in a new headliner.
Offline 1970A66D21
  • Livin in Vegas
« Reply #4 on: November 30, 2012 - 09:56:58 PM »
I installed my headliner myself and did not mark the holes for the mirror,visors or dome light but you can feel the tapered holes through the fabric easy enough as long as you know the orientation.Made no mistakes.
« Reply #5 on: November 30, 2012 - 11:02:18 PM »
Thanks to all!
Rear View & visors and Passenger seat installed.
Now plumbing the AT cooler lines......Hang the exhaust........wire the ignition.....the list goes on & on
eh
Offline MY J0B
« Reply #6 on: December 01, 2012 - 07:42:12 AM »
Before installing a new headliner, put screws in all the appropriate holes. After, the installation it's a lot easier to find the screws. Then poke your Phillips screw driver through the material and take the screw out....Now you have located your holes and the headliner has holes for the new screws. :clapping:
Offline AndrewW
« Reply #7 on: December 22, 2012 - 09:52:27 AM »
Hello, I don't mean to hijack your thread, but I am getting ready to install my headliner and think I am missing some brackets that go on before the headliner is installed. I have found a picture of the shoulder belt clip brackets.  Are there any other brackets that I might need, such as for the coat hanger? I bought this car taken apart and in boxes and finding out that I am missing a lot of the little pieces :pullinghair:
1970 Challenger RT
« Reply #8 on: December 22, 2012 - 10:57:46 AM »
I think most of that stuff goes on after the headliner is installed. The only thing I recall pre installed was the dome light ? I have pictures of most of my roof prior to install if that will help?
eh
I am building out of a box of parts too!
Offline AndrewW
« Reply #9 on: December 22, 2012 - 11:41:48 AM »
Here is a picture I found.  It looks like they screw to the roof rail then the headliner goes over the bracket.
1970 Challenger RT
Offline 73EStroker
« Reply #10 on: December 23, 2012 - 06:12:21 PM »
I found my mirror holes by poking a sewing pin through the vinyl. The hole is so small that it is not visible if you miss. Turned out I got mine first time anyway. Grope around by pressing your finger on the mounting spot and you will feel where it is supposed to go. Once you find one hole you can mount the mirror and that will guide you to the other two.
Barry (Salmon Arm)
