Author Topic: Power steering  (Read 530 times)
Offline Lloyd Wenger
  • Newbie
Power steering
« on: December 01, 2012 - 02:25:04 PM »
I have a 70 Challenger with manual steering was wondering other than the usual components like the steering box pump lines etc. what else is going to be different? Do I need
a different coupler, steering shaft???? New at this any advice or informationg would be greatly apperciated!
Re: Power steering
« Reply #1 on: December 01, 2012 - 09:13:23 PM »
The steering box is taller so the steering shaft needs to be shorter , power steering columns should be easier to find than manual , the coupler is usually different also , I would recommend getting a Firm Feel or Steer & Gear box with the firmer feel while you are doing the conversion . Pitman arm may be different also. Firm feel can fill you in on what parts you need .
« Last Edit: December 02, 2012 - 06:04:52 PM by Chryco Psycho »
