Ok so, my brother's 340 demon has been smoking a lot from the drivers side exhaust and also is spitting out a really viscous oil/coolant mix. He brought it over today and i checked the oil, really milky, so obviously coolant in it, pulled the valve cover first and found a broken rocker on the intake valve of the cylinder closest to the firewall on the driver side. Then i pulled the heads and found more milky crap in the same cylinder. Any ideas? The head gasket seemed to be fine, but there is obviously an issue, the valley was full of puddles of milky sludge wherever there was a low spot. WTF? Thanks
FYI its a 70 340 block and 73 J heads
