Author Topic: Nothing like a milky discharge to ruin a weekend!  (Read 1956 times)
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
Re: Nothing like a milky discharge to ruin a weekend!
« Reply #15 on: December 04, 2012 - 11:49:42 PM »
Definitely a problem in #7 cyl. The piston is washed. You didn't pressure test the cooling system
 before you removed the head did you? Any pic's of the gasket?
Here's the head gaskets, not sure which one is which, i think the bottom one is the one from the problem side
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
« Reply #16 on: December 05, 2012 - 08:23:30 AM »
Did you use teflon sealer on the head bolts/studs?  I never trust that they don't go into water.
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #17 on: December 05, 2012 - 08:47:00 AM »
I'm not sure why was used, he bought Ut with this motor in it, my brother says the guy he bought it from, who put together the toP end, said he has had trouble with summit brand intake manifolds and gaskets sealing before, and the intake manifold and gaskets were all summit, not sure if that could be the problem, or if he was just trying to give my brother an excuse for problems to come
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
UPDATE!
« Reply #18 on: December 05, 2012 - 05:49:40 PM »
Took the heads to a local MOPAR enthusiast machine shop, the heAD in question is warped .005, he says he will mill them both for $30, so gonna do that and put her back together and hope and pray!
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
« Reply #19 on: December 05, 2012 - 09:28:15 PM »
the lower gasket looks wrong around the head bolt / water passage towards the lifter valley , second head bolt in , I would chase all the head bolt holes & make sure the bolts will thread all the way down , Use a Felpro gasket
