Author Topic: Nothing like a milky discharge to ruin a weekend!  (Read 1959 times)
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« on: December 02, 2012 - 07:44:17 PM »
Ok so, my brother's 340 demon has been smoking a lot from the drivers side exhaust and also is spitting out a really viscous oil/coolant mix.  He brought it over today and i checked the oil, really milky, so obviously coolant in it, pulled the valve cover first and found a broken rocker on the intake valve of the cylinder closest to the firewall on the driver side.  Then i pulled the heads and found more milky crap in the same cylinder.  Any ideas?  The head gasket seemed to be fine, but there is obviously an issue, the  valley was full of puddles of milky sludge wherever there was a low spot.  WTF?  Thanks
FYI its a 70 340 block and 73 J heads
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
Re: Nothing like a milky discharge to ruin a weekend!
« Reply #1 on: December 02, 2012 - 07:48:45 PM »
cylinders
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #2 on: December 02, 2012 - 07:49:21 PM »
Close up
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
Offline Skunkworks Challenger
  • Mopars forever!
« Reply #3 on: December 02, 2012 - 08:30:12 PM »
Looking at the pictures I think I see liquid in all four cylinders?  Must be a cracked intake manifold.
The Brewmaster
« Reply #4 on: December 02, 2012 - 08:32:46 PM »
could be as simple as a bad head gasket , I have seen rockers fail before .
Offline 72cudamaan
« Reply #5 on: December 02, 2012 - 08:48:16 PM »
Definitely a problem in #7 cyl. The piston is washed. You didn't pressure test the cooling system
 before you removed the head did you? Any pic's of the gasket?
If I cant fix it, it's broke
Andy  (phukker whither)
Offline 72cudamaan
« Reply #6 on: December 02, 2012 - 08:50:21 PM »
It also looks like the head bolt at the 10 o clock position of #7 may have been loose or
over stretched. Seems awfully clean there compared to the rest of the deck.
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #7 on: December 02, 2012 - 10:24:00 PM »
Dont have a pic of the gasket, already tossed it, looked good though, couldnt find any flaws in it, i will have to look into the manifold, didnt think of that.  Could the head be cracked?
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
Offline 72cudamaan
« Reply #8 on: December 02, 2012 - 10:56:48 PM »
I assumed that coolant came out of the head when it was unbolted. Was the coolant drained before the head was
taken off?
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #9 on: December 03, 2012 - 12:10:27 AM »
taken off?
You would be right Cudmaan, coolant came from the head, however, when the head came off initially, the 2 cylinders to the left had bright green coolant, the third had a little bit of coolant/oil mix floating on top of clean coolant, and the last cylinder had only the milky mix
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
« Reply #10 on: December 03, 2012 - 07:24:46 AM »
The head could have a problem & is worth checking but I doubt it , sometimes it can be a simple as dirt in the threads & the head bolt reached torque before it clamped the head down
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #11 on: December 03, 2012 - 11:44:49 AM »
How can I clean em out without pulling the motor?
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
  • Mopars forever!
« Reply #12 on: December 03, 2012 - 11:52:48 AM »
Quote
Use a thread chaser--not a tap, then a rotary wire brush in a drill motor followed by flushing with brake- clean or similar.
The Brewmaster
Offline vinb
« Reply #13 on: December 03, 2012 - 08:08:06 PM »
Had a few push rods go threw those junk stock rockers, they don't like 6800 rpm's much, but in NHRA Stock rules are rules, now 15 years later you can use any steel replacement which are 99% better.
Those stock rocker ratio's are bad anyway 1.41 to maybe 1.43 that's it...
Looks like you have a bit more problems, to bad it wasn't the rockers and push rods..
Your going to that much trouble , I'd pull the engine and check everything, (don't do it twice)...
Get it fixed up.. :2thumbs:
« Last Edit: December 03, 2012 - 08:12:01 PM by vinb »
Offline jimynick
« Reply #14 on: December 03, 2012 - 10:30:12 PM »
"Your going to that much trouble , I'd pull the engine and check everything, (don't do it twice)..."
What the man said. Send the head out and have it checked for flatness and a pressure and mag test wouldn't be overkill, either. You can mop out and blow clean the cylinders, but be sure to give them a wipe with a clean, oiled rag before buttoning on that head. Laying a good, known straightedge on the block and ensuring there's no more than .002" max warpage would be a good idea as well. Drop the oil and filter right away and once you get it running, I'd run it for 20 minutes and then dump it again, filter and all. Keep and eye on your oil pressure, because you may have damaged the rod/main or cam bearings running that slurry in it. If it were mine, it'd come out and apart, so that I could sleep at night.  :2cents:
