Author Topic: disc brake conversion questions  (Read 1107 times)
Offline barryv
« on: December 02, 2012 - 09:08:50 PM »
hi, i have a 72 barracuda that had disc brakes upgraded a few years ago. they came from a challenger. i can get another front disc brake setup from a 1976 fury. i believe they have larger rotors. can someone tell me if its worth getting the fury setup and putting them on my barracuda.thanks
Re: disc brake conversion questions
« Reply #1 on: December 02, 2012 - 10:29:27 PM »
Offline barryv
« Reply #2 on: December 02, 2012 - 10:55:39 PM »
thanks for the info. do you think its better for me to get the setup from the fury.thanks
Offline cudazappa
« Reply #3 on: December 02, 2012 - 11:05:46 PM »
As long as its a b body fury.  A C body won't be a bolt in
2015 Dart GT - Daily Driver
« Reply #4 on: December 03, 2012 - 07:37:30 AM »
IF the price is good I would go for the larger discs , the reality is there is not a ton of difference int he braking though , probably drilled rotors would help more or something like the Viper caliper upgrade giving better brake pad choices
Offline barryv
« Reply #5 on: December 03, 2012 - 07:42:03 PM »
i can get the front set of brakes for alittle less than 100 bucks. i dont think the calipers are any good and i am not sure about the rotors. if i am not driving my car hard i  wonder if getting the larger rotor setup will be noticeable.thanks for the replies
« Reply #6 on: December 03, 2012 - 10:08:30 PM »
As an option, you can re-build calipers yourself.
Really easy once you pop out the cup with compressed air.
Offline Katfish
  • 70 Challenger
« Reply #7 on: December 03, 2012 - 10:09:05 PM »
Definitely better, will you notice the difference?  Probably not IMO.   :2cents:
