Author Topic: 440 cam choice  (Read 5129 times)
440 cam choice
« on: December 03, 2012 - 04:02:04 PM »
I have KB 237 pistons, Performer RPM intake, 750cfm 3310, planning on using 440 source heads.
4 sp trans.
What would a good cam choice be? I'd like a decent idle and bottom end is more important to me than top end.
Also, are roller rockers a good place to spend a few more  $ instead of the stock rockers?
Offline 4 speed fish
Re: 440 cam choice
« Reply #1 on: December 03, 2012 - 06:34:31 PM »
I had almost the same combo.I used the comp 268 cam.Worked well and just the right idle.I would also look into the 303 voodoo.It has a little more lift and the idle should be about the same as the comp cam.I also had comp roller rockers that worked nice.They are priced thru the roof now.
Re: 440 cam choice
« Reply #2 on: December 03, 2012 - 10:47:46 PM »
Do you just want a hyd cam ? VooDoo 3 bolt is a good call .
 Factory rockers are not very accurate as far as artio & it reduces wear in the guide < PRW has stainless rockers for decent pricing
Re: 440 cam choice
« Reply #3 on: December 04, 2012 - 06:31:22 PM »
Went to prw website and they have no listing for Mopar?
Or I'm blind maybe?
Which Voodoo 3 bolt would you recommend? 303?
Re: 440 cam choice
« Reply #4 on: December 04, 2012 - 06:51:31 PM »
One of a few listed , available in 1.5 , 1.6 or 1.7 http://www.ebay.ca/itm/PRW-BB-Mopar-383-440-Stainless-Steel-Shaft-Mount-Roller-Rocker-Arms-1-6-Ratio-/380468333072?pt=Motors_Car_Truck_Parts_Accessories&hash=item5895ae0a10&vxp=mtr
 we need to do some math , what is your rear gear ratio & tires size , you do not want to be under the powerband @ 70 mph for example , , I doubt you will be & th e4spd is far more forgiving as you do not have to keep the converter locked up . overall the 303 is a great cam
 http://www.jegs.com/i/Lunati/638/10230703LK/10002/-1?parentProductId=
Re: 440 cam choice
« Reply #5 on: December 04, 2012 - 08:14:51 PM »
Here is the hyd roller I used in my 451" ? I little lumpy but still streetable IMO.
http://www.lunatipower.com/CamSpec.aspx?p=60312
Re: 440 cam choice
« Reply #6 on: December 05, 2012 - 01:40:00 PM »
3.55 8 3/4 rear with 315/35/17 tires (25.6" diameter)
I see aluminium rockers available from several vendors. Are aluminium rockers ok? I'm thinking about weight here.
Brad, what are those 'lunati' plates spanning between lifters for? Seems to me like more mass to move around.  :dunno:
Re: 440 cam choice
« Reply #7 on: December 05, 2012 - 06:31:34 PM »
They are roller lifters, keeps them from rotating.
Re: 440 cam choice
« Reply #8 on: December 05, 2012 - 09:32:20 PM »
IMO in a street engine I would not use alum rockers , Stainless or iron . Supposedly Harlands last but they cost a LOT more then regular alum rockers
Re: 440 cam choice
« Reply #9 on: December 06, 2012 - 12:49:57 PM »
Well if Aluminium doesn't last, I don't want it. Are they pretty much race only? A few passes then replace?
Re: 440 cam choice
« Reply #10 on: December 06, 2012 - 02:09:48 PM »
I have seen them fail , there are different grades of alum Crane Golds are used a lot but I have had problems with them , they can last years , depends on the spring load & keeping them lashed & not having adjuster failures etc  , the PRW are good for the $$ , Crane Iron are great but not available new right now I believe as Crane has been through financial problems so  a lot of their products are not available  now  .
Offline HP_Cuda
  • Mopar or No Car!
Re: 440 cam choice
« Reply #11 on: December 06, 2012 - 02:14:48 PM »
Harlands rock but you pay the price for longevity.
They are a thing of beauty!!!
Re: 440 cam choice
« Reply #12 on: December 06, 2012 - 05:53:04 PM »
 :eek7:  I don't like the sounds of that? Mine are aluminum, and for what they cost they better last!  :faint:
Re: 440 cam choice
« Reply #13 on: December 07, 2012 - 12:09:13 AM »
T & D have a top quaility product
Offline HP_Cuda
  • Mopar or No Car!
Re: 440 cam choice
« Reply #14 on: December 07, 2012 - 11:04:55 AM »
Hey Brad
No worries when they fail you can step up from the 1.5's then!!!!
 :roflsmiley:
B
