Author Topic: 2005 hemi crate motor 472 cubes  (Read 760 times)
Offline 71cudafish
« on: December 05, 2012 - 05:16:06 PM »
 :working:removed lower header bolt on driver side middle and a massive rush of anti  freeze comes out (niagra falls   you  might say )  , absolutly no sign of consumption?????     no white smoke ,,,  no under car leak  in that area????     where there  any   casting   issues  on   these   cast   iron heads  from   the  crate   motors   back in   05 ?????   whow :clueless:   and motor  only has  1900  miles on it :stomp: :swear:
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
Re: 2005 hemi crate motor 472 cubes
« Reply #1 on: December 05, 2012 - 05:44:06 PM »
If the coolant came out of the header bolt hole that's normal, did the same to me when I built my 392 stroker in my 05 ram.   How u plannin on getting 472 cubes from that?  Biggest I've seen is 440 from a 6.1 block, is there a kit for that?
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline 71cudafish
« Reply #2 on: December 05, 2012 - 06:29:47 PM »
thanks  moparman , do not have  to pull heads :woohoo: :cooldancing:
« Reply #3 on: December 05, 2012 - 09:30:17 PM »
Iron Head Hemi ? Seems weird to me , but if there is no other signs of a problem  use a good sealer & put it back together
