Author Topic: Adjustable Rocker Arms  (Read 827 times)
Offline cameron2502
« on: December 06, 2012 - 08:39:39 PM »
How big of camshaft can you go before you have to put adjustable rocker arms on a small block to get the correct amount of preload on the lifter.
Offline footin70rt
Re: Adjustable Rocker Arms
« Reply #1 on: December 06, 2012 - 11:38:07 PM »
Provided the heads were built correctly, proper stem height on the valves, you should not need adjustable rockers on a hydraulic cam in a Mopar.
Thomas
Driving the same 70 R/T since October 1985
Native of Bozeman, MT
« Reply #2 on: December 07, 2012 - 12:12:33 AM »
Which is ok until the spring pressures put the pushrod through the rockers arms ..
Offline 73EStroker
« Reply #3 on: December 17, 2012 - 10:45:49 PM »
I would put adjustable rockers on every install - stocker, modified, hydraulic or solid. Only way you know that you can set up perfectly.
Barry (Salmon Arm)
Offline Changin Gears
« Reply #4 on: December 17, 2012 - 10:50:35 PM »
The 1st time (and not last time) I did this was in high school in 1977:
Which is why I do this now:
