Author Topic: Replacing front disc pads.  (Read 7180 times)
« on: December 09, 2012 - 05:23:49 PM »
I'm a little embarrassed to say this, but I have never replaced the front disc brake pads on a modern vehicle.   :grinno:
On my 70, sure. But it is the same thing on my 2009 Challenger?
On my 70, it was remove 2 bolts, Remove the old pads, Apply a big C-clamp to back off the piston in the caliper, then drop in the new pads, and bolt it up.
How is it in done now?
Offline TinCuda
    • 'Cuda
Re: Replacing front disc pads.
« Reply #1 on: December 09, 2012 - 05:40:54 PM »
Is there a way that I can subscribe to this thread without admitting that I don't know either?  I have changed brake pads, discs, bearings etc on the 'Cuda, but I have not even looked real close at the Brembos on the new Challenger.  Heck, I haven't even taken off a wheel yet.
(O O [             SRT ] O O)
(O O {]{]{]||[}[}[} O O)
{||O||}
2016 Dodge Challenger Hellcat
1971 Plymouth 'Cuda 440-6
2008 Dodge Charger R/T Hemi
2015 Chrysler 200c AWD 3.6L
2000 Yamaha V-Max
Doing my part to leave a big carbon footprint!
Image Hosted by ImageShack.us
Shot at 2012-09-05
« Reply #2 on: December 09, 2012 - 06:14:07 PM »
It's basically the same now....things just look a little different.  Sometimes you only have to remove the bottom bolt.  Then the caliper will swing up and you slide it off the side.  If that doesn't work then just remove the top bolt too.  The main difference is that the front wheel bearings are sealed units now.  The rotor just pulls off the wheel studs once the caliper is removed.  Some cars require you to remove the caliper bracket first, because it wraps around the rotor.
I'm sure there are some really goofy designs but most of them are still easy to work on.
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #3 on: December 10, 2012 - 12:07:45 AM »
:iagree:  I love the throw away rotors and no wheel bearings to grease.  I put new rotors and pads on my son's '07 hemi charger.  Piece of cake.   You'll need a low profile floor jack and metric sockets.
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline Sleepychallenger
« Reply #4 on: December 10, 2012 - 09:04:47 AM »
Mek,
Not much has changed in that area, until you get into some of the odder stuff like VW where the piston has to be turned back in with a special tool.
you should  :picture: so others can see!!
Drew
Offline ChallengerHK
« Reply #5 on: December 10, 2012 - 12:20:37 PM »
Somebody told me a few months ago that there's a special procedure for impressing the piston if a car has ABS. True?
- Han Solo, Star Wars
« Reply #6 on: December 10, 2012 - 12:56:53 PM »
Not that I have ever heard of. there is a different process for bleeding an ABS system but not compressing the pistons.
Anyone else know anything different?
« Reply #7 on: December 10, 2012 - 02:24:10 PM »
I have Viper caliper(Brembo) on my 70 Challenger and found a buddy that had a slick tool for retracting the pistons. I haven't bought one yet but I will someday.
http://www.amazon.com/Kastar-Tools-KAS279-Caliper-Spreader/dp/B0079GQKDE
Now who doesn't like buying tools! It's a car guys addiction!  :lol:
I've changed the pads on the brembo it's pretty easy/straight forward.
Tapered pins and a spring clip, easy peasy
« Last Edit: December 10, 2012 - 02:41:09 PM by brads70 »
Offline TinCuda
    • 'Cuda
« Reply #8 on: December 10, 2012 - 04:14:24 PM »
Cool, thanks.  You are right, I love to buy tools like my wife loves her shoes!
(O O [             SRT ] O O)
{||O||}
2000 Yamaha V-Max
Shot at 2012-09-05
Re: Replacing front disc pads in a new Challenger.
« Reply #9 on: December 10, 2012 - 04:16:33 PM »
Just to be clear, I don't have ABS brakes. I didn't want them. I'm not aware of how they would be different from what I have.   :dunno:
This turned out to be an amazingly fun job. The toughest part was turning the scissor jack 100 times for every inch of lift.   :eek4:
It took about 30 minutes each wheel, but I heard the rear brakes may be a different ballgame.
In the first picture here, this is how my caliper looked before I touched anything.
In this second photo, I removed the 2 bolts on the back and begun taking the upper half of the caliper off. The bolts are 13MM, or 1/2 inch. Either socket will work. I tapped the caliper apart with a hammer.
In this 3rd picture, I have the top part of the caliper off. I am now using a clamp to squeeze the piston all the way back. The new brake pads will be thicker than the old ones, that's the reasoning behind this move. You would never be able to re install the top part of the caliper if you didn't do this.
In this last picture, you can see where I slid the new brake pads into the metal tabs. It will be the same for the inner brake pad.
Offline Devil
  • Forward, Together Forward
    • Ryan's Cars in Barns
« Reply #10 on: December 10, 2012 - 04:19:00 PM »
All new cars have ABS... and they have for years.  Federally mandated.
http://www.flickr.com/photos/hemipwr70/
http://carsinbarns.blogspot.com
71 Challenger R/T Clone
69 Charger R/T SE
70 Barracuda
74 Dart Swinger
93 RamCharger
88 Caprice Classic Brougham
« Reply #11 on: December 10, 2012 - 04:22:42 PM »
But in 2009, it was still an option on a Challenger S/E.
« Last Edit: December 10, 2012 - 05:20:01 PM by MEK-Dangerfield »
Offline usraptr
« Reply #12 on: December 10, 2012 - 07:43:06 PM »
I hope you put some anti-squeal grease on the back of those new pads and on the caliber bolts.  Otherwise you're gonna have squeaky brakes in a few weeks.
(Edited 8-1-17)
Offline 72cudamaan
« Reply #13 on: December 12, 2012 - 08:37:49 AM »
Mike, you shoulda put caliper slide grease on the corners of the pads so they don,t hang up. I
won't even mention not machining the rotors.  :poopoke:
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #14 on: December 12, 2012 - 10:07:50 AM »
:iagree: :stirpot:
