Author Topic: 6.1L into B-body  (Read 6321 times)
Offline Rolling_Thunder
  • only 2 things get my attention, gas and perfume
6.1L into B-body
« on: December 12, 2012 - 09:12:15 PM »
Not an E-Body but my 68 Charger.  just a teaser pic - just finishing up the installation.
Stock K member
Home brew hydroboost
Home brew disc brakes (in the works)
Tremec 3550 trans (Viper T56 in the shed)
Home Brew Hydraulic clutch
Home brew wiring
Home brew fuel system
Modified center console (auto to 4-speed)
Home Brew A/C system
8 3/4" with 3.55 SG
« Last Edit: December 12, 2012 - 09:20:04 PM by Rolling_Thunder »
2013 Dodge Challenger R/T - 5.7L / 6-speed
1973 Dodge Challenger Rallye - 340 / Auto
1968 Dodge Charger - 6.1L / 6-speed
1964 Dodge Polara - 440 8-71 / 4-speed
Offline grimmey71
Re: 6.1L into B-body
« Reply #1 on: December 12, 2012 - 09:54:27 PM »
We want step by steps of your brew sir
« Reply #2 on: December 12, 2012 - 10:10:22 PM »
Working on it -    which one first ?
Offline grimmey71
« Reply #3 on: December 12, 2012 - 11:28:16 PM »
Well I could be selfish and ask for the wiring harness, but lots of guys are doing hydro boost saps(which I am too)
« Reply #4 on: December 13, 2012 - 12:10:57 AM »
The Hydroboost was the easiest thing...       I got a rebuilt unit off a friend for free (Chevy Astro I believe) and ordered a mounting plate / socket from Talon hydraulics. I went to earls and got the fittings I needed as well as the Lines.
Bouchillon Performance was the source for the GenIII Hemi P/S pump fitting to -6AN. I made a fitting for my P/S gear box. Details given below.
These fittings allowed for the entire P/S hydroboost system to use AN fittings.
Content Added for Archival Reasons
Finally got around to that (adapting a P/S box fitting)...
I went with a -6AN x 1/2-20 for the pressure line and I believe a -6AN x 11/16-18 for the return...      this is the one that needs to be drilled out for the relief spring so protrude into...
After Drilling...
The drilling was done on a typical drill press - nothing exotic...    then I just drilled down as deep as i needed....     I measured the depth of the old fitting and found it is goes until about the mating surface between the fitting and the pump itself...      so I drilled the new fitting accordingly...     not rocket science.
Offline roadrunninMark
« Reply #5 on: January 06, 2013 - 09:57:15 PM »
I'd like to know more about the wiring harness as well.
Thanks
Offline Modern Muscle
  • Moderator
    • Modern Muscle Performance Group
« Reply #6 on: January 08, 2013 - 03:32:39 PM »
Looking great nice job  keep us posted!!!
Offline David Weber
  • MAKING OLD NEW AGAIN AND NEW OLD
    • MODERN MUSCLE PERFORMANCE GROUP
« Reply #7 on: February 23, 2013 - 06:10:22 AM »
Thanks
Home brew wiring harness is not for everyone but it sure looks like he did a very nice job with it. We use the Hot wire harness and do a control box from a 2005 RAM (without SKIM). If you want any furhter information give a call. Dave Weber 276-666-1934
« Last Edit: February 23, 2013 - 06:26:15 AM by David Weber »
Thank You
David Weber
Modern Muscle 276-666-1934
www.modernmuscleperformance.com
« Reply #8 on: April 06, 2013 - 04:55:33 PM »
^ Dave speaks the truth -  home made wiring harnesses are not for everyone.  I have been doing automotive electrical for numerous years - and the harnesses need to be made on a case by case basis depending on engine, transmission, and accessories.
The EASIEST way would be the Hot Wire harness...     I relied on them for my PCM reflash as well -  GREAT guys to deal with.
Offline grimmey71
« Reply #9 on: April 06, 2013 - 07:46:34 PM »
Hey Dave I'm getting real close to pulling th e plug and buying your harness and PCM kit , but was wondering what radiator hoses you use for your radiator also? Thanks in advance and ill call when I get my taxes!
Offline David Weber
« Reply #10 on: April 07, 2013 - 08:42:21 AM »
The hoses I have used were simply a trip to the local parts store with measurements and a wire pattern in hand, Went through what they had on rack and even if it ment scrapping a 3 foot hose to find a preformed section for what I wanted, that is what I did. Not very scientific but it is one way to get it done. I did save some Gates numbers from some past projects but will have to dig for them.
Thank You
David Weber
« Reply #11 on: April 10, 2013 - 10:00:26 AM »
Roll,
Any updates on your how to spread sheets?  Would sure like your step by step expertise on all of your mods!
Thanks
« Reply #12 on: April 14, 2013 - 01:28:42 AM »
Still working on it -  but between working full time, getting fit, and pending enlistment in the USAF i've been pretty busy.    If you have any specific questions just ask and i'll get to them.    :jumping:
« Reply #13 on: April 15, 2013 - 01:20:18 PM »
Yeah, that is a pretty busy schedule.
Well, I like the hydro-boost (you sent me basics on that but would like a detail how to and years of cars parts came from, I already have the new m/c.  What yr chevy astro, mounting plate/ socket from Talon electronics (do they have a part # on it?).  Did you have to change the m/c pushrod or how does that work?  Did you need to drill any additional holes or do any custum hook up to the brake pedal
Definitely would like to know how you did the wiring harness, etc for a hemi conversion.
I can't remember off hand what other mods you did.
Thanks,
Mark
« Reply #14 on: April 19, 2013 - 10:33:05 PM »
my hydroboost was a 1993 application IIRC
U got a assortment of pushrods with mine (from my friend who rebuilt it) and used the appropriate length one to put the brake pedal even with the clutch pedal. (always hated the power brake pedal being lower than the clutch)
I removed the hydroboost pushrod later on because it was too long for the master cylinder I was using. I turned it down on my mini=lathe down to the appropiate length. (mine was changed to a longer pushrod when it was rebuilt)
I then used the banjo fittings and AN fittings for the plumbing.
I did not have to drill any holes in my brake pedal.
