Author Topic: Challenger transmission  (Read 990 times)
Offline blown motor
« on: December 12, 2012 - 10:50:10 PM »
I have a 74 Challenger with a 340, 4 barrel, headers, the works. 3.23 rear end and 904 transmission. The day we put it into storage for the winter it wouldn't shift right. No time to check it out then and so it sits. If the problem is serious do I rebuild the 904 or look for a 727?
Offline jimynick
Re: Challenger transmission
« Reply #1 on: December 12, 2012 - 11:10:31 PM »
Well, I've got the same car, only with a 4 speed, but Mother Mopar put a 727 behind the 340's for a reason. Just my  :2cents:
Offline 72bluNblu
« Reply #2 on: December 13, 2012 - 12:58:49 AM »
If you're not racing, there's nothing wrong with the 904's. They weigh less, and have less drivetrain loss than a 727. In fact, quite a few racers use them because they're more efficient- although they do have to be built up for that.
If you're planning for big horsepower down the road, getting a 727 may not be a bad idea. But if you're going to stay under 450 hp, a good rebuild and replacing a couple of key components will dramatically improve the 904.
But just because it "wouldn't shift right" doesn't mean you need a rebuild. More than likely it just needs fluid, or maybe a minor band adjustment. I was having shifting issues with mine, I thought I was in trouble. I dropped the pan, replaced the filter and fluid (both of which looked like hell), and viola, it shifted fine. Just because it doesn't have a drain plug doesn't mean the fluid doesn't need to be changed.
Offline blown motor
« Reply #3 on: December 13, 2012 - 09:16:52 AM »
It acted like it was low on fluid but it wasn't. I don't see pushing it up over 450HP. I'm not racing it, just having fun driving it. As much as I love winter I can't wait for spring to get it out again :-)
Offline GranCuda1970
« Reply #4 on: December 13, 2012 - 09:39:14 AM »
Screw winter!!  I'm driving mine today when the roads dry off dripping or not  :ylsuper: Gotta get them Mopars out on the road to satisfy the Hot Rod Base.
Offline blown motor
« Reply #5 on: December 15, 2012 - 12:59:56 PM »
72, what has to be done to 'build it up'? What 'key components' need to be replaced to improve performance.
Offline 72bluNblu
« Reply #6 on: December 16, 2012 - 08:26:19 PM »
 First let me qualify this by saying that I am by no means an auto transmission expert. That said, the rear sprag is one of the weaker links in the 904, and there are bolt in aftermarket sprags that can significantly improve on that. Other than that, get a good converter, higher quality bands, and rebuild it with shift kit, probably a Transgo TF2 for a street car. With 450 hp and mostly street time, that should be more than enough to keep your 904 happy. I know the 904's can be built up to handle a lot more than that, but of course it's all about how much money you want to spend...
Offline tactransman
« Reply #7 on: December 29, 2012 - 11:37:49 PM »
If you can get a 727 core cheap enough, it doesn't cost much more to rebuild a 727 than a 904..................
Terry-tactransman
Union, Mo.
