Author Topic: 1971 Challenger 440-6, Clutch/Ignition Switch  (Read 1132 times)
Offline pscaraf
  • Newbie
« on: December 16, 2012 - 10:04:23 PM »
I'm trying to find a replacment for the Clutch/Ignition Switch that's mounted on the clutch pedal and allows voltage to route to the starter relay when the clutch is depressed. I presume that this will be OEM only and I'm not having any luck finding one....any ideas would be greatly appriciated. Thanks
Offline MY J0B
Re: 1971 Challenger 440-6, Clutch/Ignition Switch
« Reply #1 on: December 17, 2012 - 07:33:09 AM »
Try contacting Jules the wiperman.
I'm also pretty certain Brewers has them.
« Reply #2 on: December 17, 2012 - 07:39:07 AM »
On one car I made a bracket & just used a brake switch so when the pedal was full depressed it with push the brake switch , $5 instead of $200 actually I think it was the other way , the brake switch opens the circuit when the pedal is against it so it would connect as soon as the pedal was depressed , but it got us past a safety inspection  :2thumbs:
« Last Edit: December 17, 2012 - 09:14:54 PM by Chryco Psycho »
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #3 on: December 17, 2012 - 09:14:25 AM »
 :iagree:  Same here.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline Grec
« Reply #4 on: December 18, 2012 - 06:44:57 PM »
If you care about originality, they show up on ebay occasionally.
I used to search for "mopar clutch safety"
They are specific to e-bodies...
I scored one for just at $125 shipped in excellent condition.
As mentioned, Brewers also sells them.
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Offline GranCuda1970
« Reply #5 on: December 20, 2012 - 11:27:16 PM »
I bought the brewers one she is a spendy doggie!! and most likely you will have to extend the wire to reach the relay going properly around the booster in the main harness pretty easy.
