Author Topic: Lower Speedo Cable Grommet question  (Read 580 times)
« on: December 19, 2012 - 09:33:11 PM »
So I looked at my OEM cable and I see the lower rubber grommet that was put on prior before each end, installed by the factory.
I could cut this in half and try to re-glue it on where it goes.
I have doubts this'll work doing that.
Any suggestions to make this work like it should be?
« Last Edit: December 19, 2012 - 09:35:26 PM by Topcat »
Offline dutch
Re: Lower Speedo Cable Grommet question
« Reply #1 on: December 20, 2012 - 12:35:51 AM »
have you tried soaking it in really hot water and using soap to pull it off?  guess you did.... I have it somewhere in a crate so dont know exactely what it looks like   :clueless:
*** Bart ***
« Reply #2 on: December 20, 2012 - 01:13:41 AM »
Hadn't thought of doing that. Worth a try.
thanks
« Reply #3 on: December 20, 2012 - 07:30:34 AM »
silicone lube , assuming the rubber is reasonably soft .
Offline swede-cuda
« Reply #4 on: December 29, 2012 - 02:14:06 PM »
 :wave: i bought a nos on ebay.when i recieved it i noticed it was cut through the radie,radious??anyway,i asked the seller and he said the replacement grommets where like that? i bet if you cut the grommet with a razor,it will settle fine in the hole in the firewall when you install it.  :clueless:
