Author Topic: Maybe bolt hole Question  (Read 1650 times)
Offline daveh
« on: December 20, 2012 - 03:02:16 PM »
Hey guys,
In the picture labeled Pass #1 & #2 I've circled in red a hole that I don't know what attaches there.  It has definatley been cut.  Or do I just weld in a new piece of steel figuring someone cut it to route through something?  I have a similar hole on the other side, labeled Drivers #1 & #2 but with a nut with the bolt still in there.  So am I missing something?  Do I weld in a new piece of metal with a bolt or just a patch?  Is it missing something?  Or are both sides suppose to be different?  Since the car was partially taken apart when I got it I don't know what attaches to it if anything.  I'm guessing the fender????  Can you guys help me out?  Thanks
Offline dutch
Re: Maybe bolt hole Question
« Reply #1 on: December 20, 2012 - 03:38:26 PM »
here`s what it looked like on my 70 cuda
*** Bart ***
Offline CUDA JAS
  • vroooooom!
« Reply #2 on: December 20, 2012 - 04:18:46 PM »
Those bolts help to hold in the inner fendser splash sheilds.
But it looks like you are missing the threaded inserts.
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline daveh
« Reply #3 on: December 20, 2012 - 04:32:43 PM »
Does anyone have a picture that I could see?  What size would it be?  Thanks
« Reply #4 on: December 20, 2012 - 07:38:48 PM »
there should be a square anchor pinched into that hole 5/16 as I recall , Can't you see the pix Dutch posted ?
Offline daveh
« Reply #5 on: December 20, 2012 - 10:10:42 PM »
Thanks does anyone have a picture of the splash shield attached that I could look at?
Why does Dutch's picture have that hole in it and mine doesn't?
And where can I get that anchor?  Thanks
dave
Offline jimynick
« Reply #6 on: December 20, 2012 - 10:16:37 PM »
You'd have to salvage one out of another car or just buy a washer-integral 5/16" nut and mig it in, fill in the holes and grind the welds.  :2cents:
Offline CUDA JAS
  • vroooooom!
« Reply #7 on: December 21, 2012 - 10:40:41 PM »
Sorry man, the splash sheilds are out of mine while I rebuild the front suspension.
Jason
74 'cuda 360/727
Offline daveh
« Reply #8 on: December 21, 2012 - 10:45:14 PM »
Thanks anyway I appreciate it.
Offline 7071 challenger
  • All you need is Dodge!
« Reply #9 on: December 26, 2012 - 04:20:05 PM »
These are the splash guards you need. I would have like to show you when they are installed, but this is the only pic I have, (car is at the body shop at the moment). They fill the space between the end of the cowl dash and the fender. The bottom hole of the guard align with the hole you are talking about. The lower hole use a 5/16" bolt while all the others holes use metal screws and flat washers. Splash guards part numbers are 2895554 & 2895555.
Robert
Offline daveh
« Reply #10 on: December 28, 2012 - 10:35:29 AM »
That's perfect Robert thanks.  I just neet to get my guards out of storage so I can weld in a new bold in the right location.  Happy New Year all.
Offline elmoska
« Reply #11 on: December 29, 2012 - 11:57:20 AM »
this is a picture of my 74 challenger's right splash shield installed...but not yet fixed, hope it can help
1974 challenger on its way..
Offline elmoska
« Reply #12 on: December 30, 2012 - 11:13:03 AM »
i just have to find the right bolt that can get those splash shield fixed
