Author Topic: speedometer bounces excessively  (Read 856 times)
Offline ff6849
« on: December 23, 2012 - 01:12:32 PM »
 I installed a complete set of Autometer gauges, what would cause the speedometer to bounce excessively, it is a mechanical speedmeter and connected to a  727 transmission.
(__________]]]]]}~~~~
73 440 Cuda'
915 heads (mild head work, stock bottom end 10/9:1 compression)
A518 2600-2800 Stall
4.10 rear gear
TTI headers with 3' exhaust with  X pipe
comp XE274H cam
Hughes Roller Rockers
Holley Sniper EFI
Holley Street Dominator intake
MSD ignition
Offline Jamiez
  • Retro
Re: speedometer bounces excessively
« Reply #1 on: December 23, 2012 - 01:38:48 PM »
I would check the cable.  It might need to be lubed or it might have been damaged (partial melting against an exhaust pipe is common.
you can disconnect the transmission end, and connect it to a drill and spin it if you need to bench test it.
Offline _Russ_
  • Not very family friendly!
  • Chk Chk Boom!
    • Show Me How To Live
« Reply #2 on: December 23, 2012 - 01:49:43 PM »
Mine was the same. Had a look underneath and it had burnt through from the exhaust. It eventually stopped working. Replaced with a new one and was good to go.
Mine only bounced between 40-60 mph. Either side of that range and it was fine.
« Reply #3 on: December 23, 2012 - 04:05:40 PM »
But curious. Can you damage the speedo if you spin it backwards?
Offline Jamiez
  • Retro
« Reply #4 on: December 23, 2012 - 04:29:24 PM »
Maybe if you really gun the drill you could.  If you go slow it shouldn't be a problem.  I've spun mine both ways trying to get everything set.  Usually I just want it to read somewhere around 5-20mph just to make sure I have it connected okay.
