Author Topic: Which headers for the 360 and why?  (Read 1548 times)
Offline mach3107
« on: December 26, 2012 - 10:42:16 PM »
Finally ready to buy headers for my 73 challenger with a 408, 727 and manual steering. What are the reviews (pros and cons) between the Hooker Super Comp 5115-1HKR ($695), Doug's Headers D453 ($605), and TTI340BE-C2 ($680).
Re: Which headers for the 360 and why?
« Reply #1 on: December 27, 2012 - 01:02:45 AM »
TTI , best quality & fit , heavy materials too.
 Dougs would be my second choice
Offline cudabob496
« Reply #2 on: December 27, 2012 - 04:32:25 AM »
I would assume diameter depends on peak horsepower.
500hp, maybe 1 and 7/8
600hp, maybe 2 inch
2011 Kawasaki Z1000
Offline 67vertman
  • Member since 9-23-2005
« Reply #3 on: December 27, 2012 - 10:24:28 AM »
I bought the TTIs for mine, great quality and craftmanship as well as fit.  I bought the full package, headers, collectors, and tailpipes.
Offline mach3107
« Reply #4 on: December 27, 2012 - 12:02:54 PM »
Thanks for the help guys. All my dad can remember about headers is 30 years ago and cursing every time the gaskets blow. 410 dynoed at 515hp. Will any of them give any problems with steering or shift (console) linkages? Hoping for something not terrible to install. And will I need a mini starter?
« Reply #5 on: December 27, 2012 - 03:28:01 PM »
You should be fine , TTi will clear steering & console shift linkages etc maybe the 70 with the column interlock , TTi has test fitted everything & will tell you what problems you may have , & they will work with either mini or regular starter
Offline cudazappa
« Reply #6 on: December 27, 2012 - 07:05:10 PM »
I went with Doug's for my 360.  They fit tight up into the car and look great.  I would go with TTIs if you need a larger primary runner for your motor.  But I think I did well with my choice.
2015 Dart GT - Daily Driver
Offline femtnmax
« Reply #7 on: December 27, 2012 - 08:53:20 PM »
I also went with Dougs.  Cheaper than TTI, easy installation, good fit and ground clearance.  Hooker Super Comp are too close to spark plug wires #5 & #7 cylinders, and the larger pipe size is a crowded fit in places; I had a set and sold them, went with Dougs and have been happy.
Phil
Offline loco340cuda
« Reply #8 on: December 27, 2012 - 09:25:58 PM »
 :iagree:  I have TTI's on my Cuda and they fit great.
1970 Cuda 340 4-speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
