Author Topic: 71 dart  (Read 1584 times)
Offline pyrojim
  • 1971 Dart, 2013 srt8, 2011 F150 Raptor
71 dart
« on: December 27, 2012 - 01:53:19 PM »
I am in the process of re working a 71 dodge dart I bought. It has a 360 400 hp crate motor but spent a lot of time at the track. Motor and trans were pretty much shot. When I put it back together I want to change out the alternator from the 60 amp or what ever it is to a 100 amp single wire. Any one have any insight??? I would appreciate the input on downfalls, thoings to watch for etc.
Thanks
Pyrojim
Offline 67vertman
  • Member since 9-23-2005
Re: 71 dart
« Reply #1 on: December 27, 2012 - 08:40:35 PM »
You will want to bypass the amp gauge and run the wire to the starter relay,
here are the diagrams.
Offline 74challenger03
Re: 71 dart
« Reply #2 on: December 28, 2012 - 08:35:57 AM »
pm dodj, he is very smart on stuff like this. Good luck
Offline pyrojim
Re: 71 dart
« Reply #3 on: December 28, 2012 - 09:34:24 AM »
Thanks 67Vertman, that info is very helpful and I appreciate it!
Pyrojim
Re: 71 dart
« Reply #4 on: December 28, 2012 - 07:07:53 PM »
The bypass wire is taking the load off your bulkhead, but I would think if you change to a higher amp alt you will need to do more then a bypass wire. Will the voltage regulator handle the amps,your inline fuses? Something to check out so you dont burn up anything.
Offline pyrojim
Re: 71 dart
« Reply #5 on: December 31, 2012 - 10:48:21 AM »
So, I took the alternator to a rebuild shop, the guy said he will rebuild the original but raise it to 120 amps (up from 60).
He says that wont be a problem. Any thoughts? I specifically asks if that puts my electrical system at risk and he said no??
I have to believe him since it only puts ourt what is required at any given time. Again, any input?
Thanks
Pyrojim
Re: 71 dart
« Reply #6 on: December 31, 2012 - 11:00:49 AM »
the Regulator can easily handle it , all it does is switch the field circuit ground .
I also agree that the alt just puts out the minimum to keep the system / battery at 14 v but If you are running a lot of accessories you can exceed 60 amps , for example we were running 2 electric fans , electric water pump , EFI , 2 fuel pumps + the usual accessories & the battery was going dead while running so we had to have a 100+ Amp alt to feed enough power , this will overload the factory ammeter & burn or melt it + can overload the wires only rated for 60 amps so I would definatly run the bypass, if the battery was dead for example the alt will go to full charge ! The real question could be asked - is if you do not need more than 60 amps why have 120 amp alt ??
Re: 71 dart
« Reply #7 on: December 31, 2012 - 11:23:35 AM »
:iagree: If original, you need to mod the electrical system.
If it was a track car, does it still have the original wiring or was it stripped for racing and you are putting it back to streetable form?
Offline pyrojim
Re: 71 dart
« Reply #8 on: January 02, 2013 - 09:30:57 AM »
It has the original wiring, althought the harnasses have been retro fitted, and poorly I may add. I know there are some grounding issues, but there is also a stereo that has two BIG amps in the trunk. To sum it up, I don't think 120 is required but 60 seems underpowered or at best, borderline.
Pyrojim
Offline pyrojim
Re: 71 dart
« Reply #9 on: January 02, 2013 - 11:11:45 AM »
I need to reiterate, this is the stock alternator, not a single wire after market.
Pyrojim
